Unadrafter Posted July 12, 2010 Posted July 12, 2010 Hi. I work with HVAC drawings. When converting a CAD file into an "existing conditions" format for showing demolition and "new-to-existing" connections, I frequently have to replace air device "tag" blocks in drawings with different ones that show only the airflow through the devices. As there can be several hundred of these blocks in a project, I'm endeavoring to write a lisp routine that will automate this replacement, The tag name we use for the airflow value is the same in both the "new equipment" and "existing condition" versions of the block. So, what I'm trying to learn to do is: 1) Create a selection set of all "ID_HEX*" (yes, a wildcard, to allow for different drawing scales) blocks. This part, I have accomplished. 2) Replace these blocks, one at a time, with a "ID_CFM*" (The wildcard corresponds to the value of the "HEX" block it replaces, for scaling,) and transferring the airflow value from the deleted block to its replacement. Each replacement would be inserted at the insert point of the "hex" block it replaces. As I stated, I've gotten as far as creating the selection set of all the "ID_HEX*" blocks that have a "XXX" tag, but that's as far as I've gotten. I still have to write the routine that goes through the selection set, extracts the insertion point and flow value from each block, and inserts its replacement block, using these two values. Any assistance anybody would be willing to share would be greatly appreciated. I understand the concepts of what I need to do, but the heavy-duty stuff is still a little beyond me. Quote
