Lee Mac Posted July 16, 2010 Posted July 16, 2010 Is it OK. You need an IF statement to allow for null input - see my post earlier. I agree with Alan here though - rewriting code and just changing the variables is not the best way to learn and it will irritate those whose code you are mutilating. Quote
Tharwat Posted July 16, 2010 Posted July 16, 2010 You need an IF statement to allow for null input - see my post earlier. Yes, you are right Lee, Thank you for helping me. I did remodified it and here it goes. (defun c:well (/ sel objs ents all) (if (/=(setq sel (ssget "_:L" '((0 . "TEXT,MTEXT"))))nil) (progn (setq objs -1) (setq ents (ssname sel (setq objs (1+ objs)))) (setq all (entget ents)) (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 all)))2 2)) (assoc 1 all) all)) ) ) (princ) ) Best regards Tharwat Quote
Lee Mac Posted July 16, 2010 Posted July 16, 2010 No need for the /= nil, see the earlier codes... Quote
Michaels Posted July 16, 2010 Posted July 16, 2010 You can try this, but it goes with one selection and I don't know why.. (defun c:try (/ sel objs ents all) (if (setq sel (ssget "_:L" '((0 . "TEXT,MTEXT")))) (progn (setq objs -1) (setq ents (ssname sel (setq objs (1+ objs)))) (setq all (entget ents)) (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 all)))2 2)) (assoc 1 all) all)) ) (princ)) ) Michaels Quote
Lee Mac Posted July 16, 2010 Posted July 16, 2010 Because you have no While loop. Seriously guys - there are working codes earlier in this thread before you guys mutilated them. Quote
Michaels Posted July 16, 2010 Posted July 16, 2010 Because you have no While loop. Seriously guys - there are working codes earlier in this thread before you guys mutilated them. Mr Lee your codes are so hard for me and for lots of people to understand, would you please say what you are indicating to clearly ...? Michaels Quote
Tharwat Posted July 16, 2010 Posted July 16, 2010 Mr Leeyour codes are so hard for me and for lots of people to understand, would you please say what you are indicating to clearly ...? Michaels Thank you Michaels. Here it goes right now you can share it with me. (defun c:try (/ sel objs ents all) (setq sel (ssget "_:L" '((0 . "TEXT,MTEXT")))) (setq objs -1) [color="Red"](while[/color] (setq ents (ssname sel (setq objs (1+ objs)))) (setq all (entget ents)) (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 all)))2 2)) (assoc 1 all) all)) ) (princ) ) Sincerly Tharwat Quote
Lee Mac Posted July 16, 2010 Posted July 16, 2010 Replace the lambda expression with (setq i -1) (defun c:R2D2 (/ ss) (if (setq ss (ssget "_:L" '((0 . "TEXT")))) [color=Red][b]((lambda (i / e l)[/b][/color] (while (setq e (ssname ss (setq i (1+ i)))) (setq l (entget e)) (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 l))) (getvar 'lunits) 2)) (assoc 1 l) l)) ) ) [color=Red][b] -1 )[/b][/color] ) (princ) ) (defun c:R2D2 (/ ss [b][color=Red]i[/color][/b]) (if (setq ss (ssget "_:L" '((0 . "TEXT")))) [color=Red][b] (progn (setq i -1)[/b][/color] (while (setq e (ssname ss (setq i (1+ i)))) (setq l (entget e)) (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 l))) (getvar 'lunits) 2)) (assoc 1 l) l)) ) [color=Red][b] )[/b][/color] ) (princ) ) All I'm saying is that instead of complaining that something doesn't work, look at the working code and compare it. Quote
ridpath Posted September 24, 2010 Posted September 24, 2010 Just found this posting via Google, thanks for the lisp folks! Quote
wing Posted October 10, 2014 Posted October 10, 2014 (edited) Not much different from Alan's code, keeping with the theme lol (defun c:C3PO ( / ss ) (if (setq ss (ssget "_:L" '((0 . "TEXT")))) ( (lambda ( i / e el ) (while (setq e (ssname ss (setq i (1+ i)))) (if (distof (cdr (assoc 1 (setq el (entget e))))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (rtos (atof (cdr (assoc 1 el) ) ) (getvar 'LUNITS) 2 ) ) (assoc 1 el) el ) ) ) ) ) ) ) ) -1 ) ) (princ) ) That's brilliant. Now, how do I force it to 2 decimals the other way? like 21.5 to 21.50 or 21.501 to 21.50. It doesn't seem to work. In both cases, the result produces 21.5. Thanks Lee Mac. I love your align to curve routine. Update: Setting DIMZIN to 0 fixed it. Edited October 10, 2014 by wing Update Quote
Lee Mac Posted October 10, 2014 Posted October 10, 2014 You're welcome! As you've gathered, DIMZIN is the key Quote
