Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Junior Member
    AutoCAD 2010
    Jun 2010
    19
    Default Insert dynamic block from file with multiple dynamic blocks
    I'm trying to find the solution but with no luck so far, so i'll ask you guys.
    I have a drawing ("SURUBURI.dwg") with several dynamic blocks ("M12", "M16", "M18" ... an so on...). I want to insert in my current drawing, one of the blocks from SURUBURI.dwg, for instance the block named "M12".
    For that i tried creating a new command "INSERT_M12" that has the following script :
    ^C^C-INSERT; "I:/Ionut Mihaila/Goodies/SURUBURI.dwg/M12"
    Now obvious that doesn't work, but i think it shows clearly what i want to accomplish. So is there an other way to do this?
    Thanks in advance!
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,124
    Why not put them on a palette?
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
    Junior Member
    AutoCAD 2010
    Jun 2010
    19
    'coz the palette takes more space of my screen, an i need it as clean as posible. i have enough space for more menus but not for a new palette
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Palettes have the facility to "auto-hide" themselves, thus keeping your screen as clean as you want it for the maximum amount of time without impacting too greatly on your efficiency
    Life's constantly changing - keep up or get left behind
  5. #5
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,124
    I have all my palettes on auto hide.
    Oh well in answer to your question, not to my knowledge.
    Dave
  6. #6
    Junior Member
    AutoCAD 2010
    Jun 2010
    19
    well, it's true that i forgot about autohide feature, so 'till i get an answer to my question, i'll use palettes.
    but then for the sake of knowledge how would an autocad specialist resolve the problem?
  7. #7
    Forum Newbie
    AutoCAD 2011
    Jan 2011
    2
    Did Anyone Come up with an answer to this??
    I would love to be able to insert a block from a file.
    Thanks
  8. #8
    Senior Member ccowgill's Avatar
    ccowgill's Computer Details
    Windows 7 64 Bit
    Asus M4A785TD-V EVO
    AMD Penom II X4 965 @ 3.4GHZ
    8GB
    ATI Radeon HD 4200 (384mb) ATI Radeon HD 5700 (1GB)
    Hitachi 1TB SATA HD
    Triple Monitor system
    AutoCAD 2012
    Dec 2010
    Hartford, Michigan
    190
    just insert the file, all the blocks inside it will come with. That's what we used to do before we started using palettes.
    you can also use the design center to insert a block from a drawing, just browse to the right dwg, click on the blocks and it will populate the design center with all the blocks in the drawing, you can even right click and create a palette from the drawing.
    Christopher T. Cowgill, P.E.
    Wightman Jones, Inc.
    Consulting Engineers & Land Surveyors
  9. #9
    Forum Newbie
    AutoCAD 2008
    Jan 2011
    8
    OK, might not be elegant (I do not have time to write the lisp, but it would not be difficult); you could use a lisp to check for the existence of the block in your drawing already, if it exists, you then use your lisp to insert it. If it does not exist then you could "ddinsert" the file itself so that all the blocks contained therein are created in your new drawing, then explode last and erase previous. The blocks would then be in your drawing, but unreferenced.
    Then you could loop back to the start.
  10. #10
    Junior Member
    MDrawings's Computer Details
    Win 7 64bit
    Asus something
    i7 860
    16gb
    Radeon 7970
    2 x 120gb ssd's in RAID 1
    3 x 24"
    AutoCAD 2012
    Jan 2011
    Canada, eh
    22
    If you're like me and don't like the auto-hide feature, you can use the hotkey CTRL+3 to bring up the the Tool Pallette quickly, pick your block then CTRL+3 again to hide it.
    I use it all the time with properties: CTRL+1.
    Or you could just use the Deign Center (CTRL+2) to grab the block you need from your file. It will be stored in the history of the design center so you can quickly reference again if you need in the future.
    There is even a search function in the Design Center so you can search for that 1 off block you made a long time ago - just hope you gave it a good description or name.
  1. I can't insert a particular dynamic block
    By cadmench in forum AutoCAD Beginners' Area
    Last Post: 2nd Sep 2011, 03:34 pm
  2. dynamic insert of a dynamic block.
    By Huibert in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jun 2010, 02:12 am
  3. multiple dynamic constraints in a dynamic block
    Last Post: 16th Jul 2009, 11:13 am
  4. Replies: 5
    Last Post: 26th Jun 2009, 04:50 pm
  5. Dynamic Blocks with insert
    By gessex in forum AutoCAD Drawing Management & Output
    Last Post: 8th Oct 2007, 10:18 pm
