HassanCAD® Posted July 19, 2010 Share Posted July 19, 2010 whts diffrents between presspull and extrude command? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 19, 2010 Share Posted July 19, 2010 Presspull does not require a closed polyline - in fact presspull boundary can be combination of lines, arcs, circles, polylines and splines. in fact presspull can be used on a face without any construction geometry (like polylines, lines....). Presspull will automatically cut without a separate solidediting command. About the only time I use Extrude anymore is if need taper, otherwise use Presspull or Sweep. Quote Link to comment Share on other sites More sharing options...
HassanCAD® Posted July 20, 2010 Author Share Posted July 20, 2010 Thank You Sir Quote Link to comment Share on other sites More sharing options...
