Alhazred Posted July 20, 2010 Posted July 20, 2010 I have an horizontal line, by selecting its vertexes my routine should put a text centered above the line. This is the code I've written, but it doesn't work, the problem occurs when the text should be printed (defun c:ferri (/ pt1 pt2 pt2x ptc) (setq pt1 (getpoint "\nSelect 1st point:")) (setq pt2 (getpoint "\nSelect 2nd point:")) (setq pt1x (car pt1)) (setq pt1y (rtos (+(cadr pt1) 0.1))) ;0.1 above the line (setq pt2x (car pt2)) (setq ptc (rtos (/ (+ pt1x pt2x) 2))) ;line's middle point (command "_text" "_justify" "_mc" '(ptc pt1y) 0.1 0.0 "Dummy text") (princ) ) The routine looks to not evalate the ptc and pt1y inside the "command", if I put there (90 30.1) the routine works. The content of ptc and pt1y is correct, I've also tried without the rtos convertion. Which is the problem? Quote
SteveK Posted July 20, 2010 Posted July 20, 2010 Quick guess, you're quoting variables, meaning they are read as their name, not their value. Instead of '(ptc pt1y), try (list ptc pt1y). Quote
Alhazred Posted July 20, 2010 Author Posted July 20, 2010 That's it, I hadn't uderstood the difference between '(...) and (list ...). Thanks. Quote
Lee Mac Posted July 20, 2010 Posted July 20, 2010 That's it, I hadn't uderstood the difference between '(...) and (list ...).Thanks. This may help: Explanation of the Apostrophe: http://www.cadtutor.net/forum/showpost.php?p=258390&postcount=20 Quote
BIGAL Posted July 21, 2010 Posted July 21, 2010 Not sure if you use car cadr etc that if your line is on an angle that you would get true 0.1 offset maybe as below ? defun c:ferri (/ pt1 pt2 pt2x ptc) (setq pt1 (getpoint "\nSelect 1st point:")) (setq pt2 (getpoint "\nSelect 2nd point:")) (setq ang (angle pt1 pt2)) (setq dist (/ (distance pt1 pt2) 2.0) ) (setq ang2 (+ ang 1.5707)) (setq pt3 (polar pt1 ang dist)) (setq pt4 (polar pt3 ang 0.1)) (command "_text" "_justify" "_mc" pt4 ang 0.0 "Dummy text") (princ) ) next step if you have lines then you can pick line rather than two points (setq objl (entsel "\nPick line : ")) (setq tpp1 (entget (car objl) ) ) (setq pt1 (cdr (assoc 10 tpp1) ) ) (setq pt2 (cdr (assoc 11 tpp1) ) ) Quote
Alhazred Posted July 23, 2010 Author Posted July 23, 2010 Thanks BIGAL, I'm now trying to do the same for lines with any angulation. I've tried to use your code, but it seems to not work for me, or it's probably me to use it incorrectly. I've used the first code you posted, but the text is not positioned at the middle of the line. I've written this other code (even if I know it is wrong), but depending on the angle of the line the text results closer or crossing the line. (defun c:test( / pt1 pt1 ang ptc offs) (setq pt1 (getpoint "\point 1")) (setq pt2 (getpoint "\npoint 2")) (setq ang (angle pt1 pt2)) (setq ang (/ (* ang 180) pi)) ; angle in degrees (setq ptc (/ (+ (car pt1) (car pt2)) 2.0)) ;middle point along X axis (setq offs (/ (+ (+ (cadr pt1) 0.1) (+ (cadr pt2) 0.1)) 2.0)) ;middle point along Y axix + 0.1 to raise the text from the line (setq puntom (list ptc offs)) (command "_text" "_justify" "_mc" puntom 0.1 ang "text") (princ) ) This is the result How can I do to have the text always at the same distance from the line and centered? Quote
