Drwhobe Posted July 22, 2010 Posted July 22, 2010 Does anyone know of a lisp routine which would allow me select a dimension and ddedit and add a standard note to the dimension selected from a drop down box of standard notes abit like Autotext in MS Word or the ability to cycle through the notes. For example the dimension would then read " O/A Width" etc. The list would need to be customisable maybe held outside Autocad in an excel spreadsheet. Does anyone have any ideas? Quote
Drwhobe Posted July 22, 2010 Author Posted July 22, 2010 Just thinking this one a bit further maybe it could be done by adding the drop down list to the mtext menu which is launched when you invoke the ddedit command. You can already insert fields and symbols maybe this would be an easier way to do this? Quote
alanjt Posted July 22, 2010 Posted July 22, 2010 You could easily construct a DCL menu with pulldown(s) (prefix and/or suffix). From there, you would select your dimensions and append the additional data. Dimension styles have an option for a prefix/suffix, but only one to choose from for each style. Quote
Lee Mac Posted July 22, 2010 Posted July 22, 2010 (edited) As a modification of an old code I wrote: (defun c:DimUpdate ( / *error* _read dcfilename strfilename strlst ss dctag ptr dcflag str ) ;; © Lee Mac 2010 (setq dcfilename "DimUpdate.dcl" ;; DCL Filename Strfilename "DimUpdate.txt" ;; Data Filename ) (defun *error* ( msg ) (and dcTag (unload_dialog dcTag)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (defun _read ( file / ofile lst nl ) (cond ( (setq ofile (open file "r")) (while (setq nl (read-line ofile)) (setq lst (cons nl lst))) (close ofile))) (reverse lst) ) (cond ( (not (setq Strfilename (findfile Strfilename))) (princ "\n** Data File not Found **")) ( (not (setq StrLst (_read Strfilename))) (princ "\n** Data File Empty **")) ( (not (setq ss (ssget "_:L" '((0 . "*DIMENSION")))))) ( (<= (setq dcTag (load_dialog dcfilename)) 0) (princ "\n** Dialog Definition Not Found **")) ( (not (new_dialog "dimupdate" dcTag)) (princ "\n** Dialog Could not be Loaded **")) (t (start_list "lst") (mapcar (function add_list) StrLst) (end_list) (set_tile "dcltitle" "Dimension Notes") (setq ptr (set_tile "lst" "0")) (action_tile "lst" "(setq ptr $value)") (setq dcFlag (start_dialog) dcTag (unload_dialog dcTag) Str (nth (atoi ptr) StrLst)) (if (= 1 dcFlag) ( (lambda ( i / ent ) (while (setq ent (ssname ss (setq i (1+ i)))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat "<>" str)) (assoc 1 (entget ent)) (entget ent)) ) ) ) ) ) ) -1 ) (princ "\n*Cancel*") ) ) ) (princ) ) DCL File: dimupdate : dialog { key = "dctitle"; spacer; : list_box { label = "Notes:"; key = "lst"; alignment = centered; fixed_height = true; fixed_width = true; width = 50; height = 20; } spacer; ok_cancel; } Example of Txt Data File: Dimension Note 1 Dimension Note 2 ... Make sure that the Txt and DCL files are saved to the search path under the names shown at the top of the LISP code. Lee Edited July 23, 2010 by Lee Mac Quote
Drwhobe Posted July 22, 2010 Author Posted July 22, 2010 Spot on works perfect, Just what i was looking for, I did find a way of adding text to the symbols list in the mtext editor but requires editing the registry to the add the notes to the drop down menu but your solution is alot easier to add to on a regular basis. Quote
Lee Mac Posted July 23, 2010 Posted July 23, 2010 I'm glad it works well for you EDIT: Oops! forgot to localise my variables, LSP code updated above. Quote
woodman78 Posted July 26, 2010 Posted July 26, 2010 Lee, This is a great lisp. Will save alot of time in my office. I think if it would be more efficient to preload the cursor with the text override to that it can be applied to a good few dimensions without having to restart it each time. Quote
Lee Mac Posted July 26, 2010 Posted July 26, 2010 You should be able to select a SelectionSet of Dims to apply it to - can you not? Quote
Drwhobe Posted August 4, 2010 Author Posted August 4, 2010 Lee, Could this code be modified to work with standard Mtext, for example if i wanted to add text to a note either as a prefix or a suffix. Maybe as a separate lisp and dialogue, and maybe dtext aswell. Quote
Lee Mac Posted August 4, 2010 Posted August 4, 2010 As a VERY quick modification: (defun c:TxtUpdate ( / *error* _read dcfilename strfilename strlst ss dctag ptr dcflag str ) ;; © Lee Mac 2010 (setq dcfilename "txtUpdate.dcl" ;; DCL Filename Strfilename "txtUpdate.txt" ;; Data Filename ) (defun *error* ( msg ) (and dcTag (unload_dialog dcTag)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (defun _read ( file / ofile lst nl ) (cond ( (setq ofile (open file "r")) (while (setq nl (read-line ofile)) (setq lst (cons nl lst))) (close ofile))) (reverse lst) ) (cond ( (not (setq Strfilename (findfile Strfilename))) (princ "\n** Data File not Found **")) ( (not (setq StrLst (_read Strfilename))) (princ "\n** Data File Empty **")) ( (not (setq ss (ssget "_:L" '((0 . "*TEXT")))))) ( (<= (setq dcTag (load_dialog dcfilename)) 0) (princ "\n** Dialog Definition Not Found **")) ( (not (new_dialog "txtupdate" dcTag)) (princ "\n** Dialog Could not be Loaded **")) (t (start_list "lst") (mapcar (function add_list) StrLst) (end_list) (set_tile "dcltitle" "Text Notes") (setq ptr (set_tile "lst" "0")) (action_tile "lst" "(setq ptr $value)") (setq dcFlag (start_dialog) dcTag (unload_dialog dcTag) Str (nth (atoi ptr) StrLst)) (if (= 1 dcFlag) ( (lambda ( i / ent ) (while (setq ent (ssname ss (setq i (1+ i)))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (cdr (assoc 1 (entget ent))) str)) (assoc 1 (entget ent)) (entget ent)) ) ) ) ) ) ) -1 ) (princ "\n*Cancel*") ) ) ) (princ) ) txtupdate : dialog { key = "dctitle"; spacer; : list_box { label = "Notes:"; key = "lst"; alignment = centered; fixed_height = true; fixed_width = true; width = 50; height = 20; } spacer; ok_cancel; } Literally really only changed the names and a few other bits - and its completely untested. This may be more suited to you: http://www.theswamp.org/index.php?topic=1392.0 You might need to become a member to view it as its in a restricted section - but its one of CAB's and its well worth it Quote
Drwhobe Posted August 4, 2010 Author Posted August 4, 2010 Yep works ok would need to be able to put text as a prefix aswell as a suffix thou. How would the code be altered to do this Quote
Lee Mac Posted August 4, 2010 Posted August 4, 2010 Change: (subst (cons 1 (strcat (cdr (assoc 1 (entget ent))) str)) (assoc 1 (entget ent)) (entget ent)) to (subst (cons 1 (strcat str (cdr (assoc 1 (entget ent))))) (assoc 1 (entget ent)) (entget ent)) I'll leave the adding of prompts to you if you like - just remember to mark/initial where modifications are made. Quote
DVDM Posted August 4, 2010 Posted August 4, 2010 Sounds a bit like this, for those interested: http://www.jtbworld.com/dimnotes.htm Quote
CADapult Posted October 18, 2010 Posted October 18, 2010 This is a very handy LISP routine! Thanks very much for sharing it. I do have a question: I've added the line " \U+2104" to the associated text file to add the centerline symbol to dimensions. On my computer, using ACAD2011/Win7 64bit, the dialog box shows the centerline symbol in the list. On another machine with ACAD2008/XP Pro 64bit it shows up as a small vertical rectangle in the dialog box list. I checked Options/Display/Fonts and both copies of AutoCAD use the same font settings. Is the problem with displaying the correct symbol an operating system issue? Is there a setting in XP that will let the dialog box show the correct symbol? Thanks- Mike Quote
Lee Mac Posted October 18, 2010 Posted October 18, 2010 Thanks CADapult, glad you like it As for the display, this would be something inherent to how the DCL interacts with XP or different versions of AutoCAD, I'm not sure how one would go about changing that Quote
