Results 1 to 9 of 9
    Junior Member
    AutoCAD 2008
    Feb 2010
    14
    Default Command Alias being Superseded
    Hi all,
    Our firm has a custom program running along with our AutoCad 2008. The programmer has included the default commands along with his cutom commands within his program.
    Problem is, none of my custom shortcuts from the Command Alias Editor work. Is there anyway to give my .pgp file first preference. So far I've been able to work around it by making new aliases that do not conflict with the default aliases nor the ones in his program. Which rules out 1 letter aliases since those are all taken.
    Cad manager here does not want to discuss this with the programmer because he finds my need for this insignificant.
    Any ideas?
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    The command names (aliases) defined in lisp routines (i.e. defun c:commandname) take precedence
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    Actually since the programmer changed your .pgp file, which means that you have to re-create your won abbreviations onec again. and it does not
    tanke that much time. And it is better idea to keep a copy of your .pgp file aside after making the changes of the file.
    Tharwat
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,058
    What is the current "path" to the acad.pgp file that is being loaded?
    I'm assuming you have a copy of your own acad.pgp file available right? Do you currently have a defined "path" to the folder containing your custom pgp file included in Tools > Options > Files?
    I was always under the impression there were at least two acad.pgp files (standalone system) and perhaps more, on a networked system, and that the last one loaded was the one that got used.
  5. #5
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by jamathi View Post
    Hi all,
    Any ideas?
    A) Is there any way to disable the shortcuts defined by the custom program. A well built application will include this option.
    B) As lpseifert mentioned, lisp functions always win over pgp shortcuts.
    C) As a last resort, give up on the pgp file and put lisp defined shortcuts in "acaddoc.lsp" or "your_custom_menu.mnl" Here is the loading order of startup files, to which you may need to refer in your situation.
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    What is the current "path" to the acad.pgp file that is currently being loaded?
    The path is ; TOOLS -> CUSTOMIZE -> EDIT PROGRAM PARAMETERS
    Regards
    Tharwat
  7. #7
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by tharwat313 View Post
    No, he means where is your PGP file located, the one that AutoCAD is reading...
    To find out, paste this at the AutoCAD command line: (findfile "Acad.pgp")
  8. #8
    Junior Member
    AutoCAD 2008
    Feb 2010
    14
    Some quick answers, the prommer did not modify my .pgp file, it is still the same.
    The program doesn't have a disable to it, only way is to deallocate the files loading but that would cause huge issues.
    It makes sense that the lisp supersedes the .pgp
    I will look into making the lisp that has my shorcuts in it as mentioned by rkmcswain..... Just don't know how
  9. #9
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Here is a portion of my acaddoc.lsp file to give you an idea... the file can be created with Notepad- save as acaddoc.lsp somewhere in acad's support path.
    the letters after (defun c: will be the 'shortcut'
    Code:
    (defun c:ue ()(command "ucs" "e"))
    (defun c:ul ()(command "ucs" "e" "l"))
    (defun c:uw ()(command "ucs" "w"))
    (defun c:uv ()(command "ucs" "v"))
    (defun c:up ()(command "ucs" "p"))
    (defun c:w ()(command "zoom" "w"))
    (defun c:p ()(command "zoom" "p"))
    (defun c:ze ()(command "zoom" "e"))
    (defun c:zo ()(command "zoom" "o"))
    (defun C:A ()( COMMAND "ZOOM" "E" "Zoom" "0.99x")(princ))
    (defun C:RZ ()( COMMAND "UCS" "Z" "90"))
    (defun c:rx ()(command "ucs" "x" "90"))
    (defun c:ry ()(command "ucs" "y" "90"))
    (defun C:AO ()( COMMAND "AREA" "O" ))
    (defun C:AOL ()( COMMAND "AREA" "O" "L" ))
    (DEFUN C:W1 ()(COMMAND"WIPEOUT" "F" "ON"))
    (DEFUN C:W0 ()(COMMAND"WIPEOUT" "F" "OFF"))
    (defun c:lt() (command "_lengthen" "T"))
    (defun c:ld() (command "_lengthen" "DE"))
    (defun c:ldy () (command "_lengthen" "dy"))
    (defun c: s() (command "stretch" "C"))
    (defun c:c2 () (command "circle" "2P"))
    (defun c:ct () (command "circle" "t"))
  1. LISP to Copy Current DWG to Superseded Folder
    By cleasc in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Aug 2012, 09:56 pm
  2. 2 Step Command Alias in PGP File
    By EVGA Buzzer in forum AutoCAD Beginners' Area
    Last Post: 3rd Aug 2010, 07:24 pm
  3. Becoming a Keyboard Warrior – The Command Alias Editor
    By The CAD Geek Blog in forum AutoCAD RSS Feeds
    Last Post: 6th May 2009, 10:10 am
  4. Alias for New Command
    By arm54 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jun 2008, 10:35 pm
  5. Tutorial: Create a command alias (keyboard shortcut)
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 18th Mar 2007, 12:11 am
