rexanteria Posted July 31, 2010 Share Posted July 31, 2010 im using autocad architecture 2008...pls help me.. i cant make the window glass transparent... and how can i add reflection on the window glass?? thanks... Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 31, 2010 Share Posted July 31, 2010 It would help if you could post your rendered image. Are you using one of the pre-made glass materials that ships with Autocad or have you created your own? Have you rendered your scene or are you just viewing your model in the editor? Have you added lights and other objects around the glass so you can see if it's working? Quote Link to comment Share on other sites More sharing options...
DAMO Posted August 4, 2010 Share Posted August 4, 2010 Hi Rexanteria, In the stylemanager under Multi Purpose Objects --> Material Definions you should change a value in the display Representations, display properties,Rendermaterial. Here you can change the material you want to see! Be sure you've put the right material in the current drawing! Quote Link to comment Share on other sites More sharing options...
