A very long time ago, I encounter a routine called Detail, the main function is to create a circle with a variable diameter, it creates the circle and all the elements inside the circle are copied then prompt to move the circle to other place in the drawing and then asks for a scale value, this is great to take elements of one drawing and places in other side with other scale to indicate a detail.
Unfortunately the routine only works once, and after this, when ask me for a circle radius, the routine wont work anymore, copying only the elements with any luck.
I put the routine for your valuable help, in advance, many thanks.
(defun dtr (a)
(* pi (/ a 180.00))
;________________________________________________________________________
(defun P_circle ( ang1 ang pt)
(repeat n
(setq new_ang (+ ang1 ang))
(setq ang1 new_ang)
(setq new_pt (polar pt new_ang rad))
(setq pt_list (append pt_list (list new_pt)))
(defun C:detail (/ pt_list a)
(setvar "cmdecho" 0)
(setq ltsc (getvar "ltscale"))
(command "ltscale" 0.05)
(command "regen")
(setq n 45)
(setq pt (getpoint "\ncenter point: "))
(prompt "\nEnter Radius: ")
(command "circle" pt pause)
(setq prop1 (entget (entlast))
rad (cdr (assoc 40 prop1))
ang (dtr 8)
ang1 0
pt1 (polar pt ang1 rad))
(setq ent1 (entlast))
(p_circle ang1 ang pt)
(prompt "\nSecond Point of Displacement: ")
(command "copy" "cp" pt1 (foreach p Pt_list (command p) "") "" pt pause)
(setq pt_list nil)
(setq pt (getvar "lastpoint")
ang1 0
ang (dtr 8)
(command "move" "cp" pt1 (foreach p Pt_list (command p)"") "" pt1 pt1)
(setq rad (+ rad (* 0.05 (getvar "dimscale")))
ang1 0
ang (dtr 12)
n 30
pt_list nil)
(command "trim" "p" "" "f" pt1 (foreach p pt_list (command p) "") "")
(setq pt_list nil
sf (getreal "\nEnter scale Factor:"))
(if (or(= sf nil)(= sf ""))(setq sf 1))
(command "scale" "p" "" pt sf)
(command "text" (getvar "viewctr") (* 0.18 sf) "" (strcat "Scale Factor " (rtos sf 2 1) "x"))
(prompt "\nSnap Text to point: ")
(command "move" (entlast) "" (getvar "viewctr") pause)
(command "erase" ent1 "")
(setvar "ltscale" ltsc)
(command "regen")
Small mistakes found as the following ...
(defun dtr (a)
(* pi (/ a 180.00))
;_________________________________________________ _______________________
(repeat n
(setq ang1 new_ang)
(command "regen")
(setq n 45)
     ang (dtr
     ang1 0
[color="red"](setq ent1 (entlast))[/color]
(setq pt_list nil)
     ang1 0
     ang (dtr
     pt1 (polar pt ang1 rad))[color="red"])[/color]
ang1 0
ang (dtr 12)
n 30
pt_list nil)
(setq pt_list nil
(command "regen")
And for entlast I think it should be followed after an action of command like Circle, Line, Pline.......
so you will get it by entlast, So that's why it give an error in your codes.
Regards
I'm afraid to say, that it wont work anymore, in the command line after opening autocad, shows a syntax error and when I load the routine, shows that the command doesn't exists
