marc578 Posted August 6, 2010 Posted August 6, 2010 Hi can anybody give an advice in order to write a LIST into a *.txt file? (defun c:prueba4() (setq a (entsel)) (setq b (entget(car a))) (setq pt1 (cdr(assoc 10 b))) (setq f(open "ppr.txt" "w")) (write-line pt1 f) (close f) ) With the previous code I got the following message: "bad argument type: stringp (39.198 28.5504 0.0)" Quote
Tharwat Posted August 6, 2010 Posted August 6, 2010 The probelm lays in the incorrect way of using (write-line). it should be with strings to write the data to file . Like : (write-line [color="red"]"[/color]Welcome to CADTutor.[color="red"]"[/color] f) Try to replace your PT1 with the previous line and it will work. Maybe someone else would have something to make it. I hope so. Regards Quote
MSasu Posted August 6, 2010 Posted August 6, 2010 Unfortunately this isn't the answer the OP was looking for - his goal was to record the coordinates of a point into a file. To do that the list must be converted into a string. Can do that using a nice function by Gile: ;;; lST2STR ;;; Returns a string which is the concatenation of a list and a separator ;;; Author: Gile ;;; Arguments ;;; str = the string ;;; sep = the separator pattern (defun lst2str (lst sep) (if (cadr lst) (strcat (vl-princ-to-string (car lst)) sep (lst2str (cdr lst) sep) ) (vl-princ-to-string (car lst)) ) ) Use it like: (LST2STR PT1 "\t") Regards, Quote
David Bethel Posted August 6, 2010 Posted August 6, 2010 use (prin1 pt1 f) to print the list to the file use (write-line "" f) for a new line Quote
muthu123 Posted August 8, 2010 Posted August 8, 2010 I hope this is the easiest way posted by Great Mr.Lee Mac. This is most useful for me to convert the string into list as well as list to string. (defun L->Ptr (lst) (princ) (vl-string-trim "()" (vl-princ-to-string lst))) (defun Ptr->L (ptr) (read (strcat "(" ptr ")"))) Quote
Lee Mac Posted August 8, 2010 Posted August 8, 2010 I hope this is the easiest way posted by Great Mr.Lee Mac. This is most useful for me to convert the string into list as well as list to string. (defun L->Ptr (lst) (princ) (vl-string-trim "()" (vl-princ-to-string lst))) (defun Ptr->L (ptr) (read (strcat "(" ptr ")"))) Muthu, as I have explained to you in the past - I never intended those functions to be used for that purpose... they were constructed to be used for manipulating DCL tile values. Quote
muthu123 Posted August 9, 2010 Posted August 9, 2010 Muthu, as I have explained to you in the past - I never intended those functions to be used for that purpose... they were constructed to be used for manipulating DCL tile values. DearLee, I agreed. But it can be useful for that purpose too and not for all the cases. If you can fine any other wat for that particular purposes (List to string & string to List) , of course it will be so much helpful to me as well as others. Regards, Muthu. Quote
muthu123 Posted August 9, 2010 Posted August 9, 2010 Unfortunately this isn't the answer the OP was looking for - his goal was to record the coordinates of a point into a file. To do that the list must be converted into a string. Can do that using a nice function by Gile: ;;; lST2STR ;;; Returns a string which is the concatenation of a list and a separator ;;; Author: Gile ;;; Arguments ;;; str = the string ;;; sep = the separator pattern (defun lst2str (lst sep) (if (cadr lst) (strcat (vl-princ-to-string (car lst)) sep (lst2str (cdr lst) sep) ) (vl-princ-to-string (car lst)) ) ) Use it like: (LST2STR PT1 "\t") Regards, Dear msasu, Good one. do u have anyother routine to conver the string into list? Regards, Muthu Quote
marc578 Posted August 9, 2010 Author Posted August 9, 2010 Hi friends, I wrote the following that work so good for me, maybe can help you too: **************************************************************** (setq a (entsel)) (setq b (entget(car a))) (setq pt1 (cdr(assoc 10 b))) (setq pt2 (cdr(assoc 11 b))) (setq f(open "C:\\Documents and Settings\\Marco\\Mis documentos\\AAA.txt" "w")) ; ******************************************************************************* (setq ptx1 (car pt1)) (setq pty1 (cadr pt1)) (setq ptz1 (caddr pt1)) ; ******************************************************************************* (setq ptx1(rtos ptx1 2 4)) ;convert data into a string (setq pty1(rtos pty1 2 4)) (setq ptz1(rtos ptz1 2 4)) ; ******************************************************************************* (setq xyz1(strcat ptx1 ", " pty1 ", " ptz1)) ; ******************************************************************************* (write-line xyz1 f) Regards Quote
Tharwat Posted August 9, 2010 Posted August 9, 2010 Hi friends, I wrote the following that work so good for me, maybe can help you too:Regards Please put your codes in codes editor. read the following link. http://www.cadtutor.net/forum/showthread.php?9184-Code-posting-guidelines Thanks. Quote
Tharwat Posted August 9, 2010 Posted August 9, 2010 Hi friends, I wrote the following that work so good for me, maybe can help you too: **************************************************************** (setq a (entsel)) (setq b (entget(car a))) (setq pt1 (cdr(assoc 10 b))) (setq pt2 (cdr(assoc 11 b))) (setq f(open "C:\\Documents and Settings\\Marco\\Mis documentos\\AAA.txt" "w")) ; ******************************************************************************* (setq ptx1 (car pt1)) (setq pty1 (cadr pt1)) (setq ptz1 (caddr pt1)) ; ******************************************************************************* (setq ptx1(rtos ptx1 2 4)) ;convert data into a string (setq pty1(rtos pty1 2 4)) (setq ptz1(rtos ptz1 2 4)) ; ******************************************************************************* (setq xyz1(strcat ptx1 ", " pty1 ", " ptz1)) ; ******************************************************************************* (write-line xyz1 f) Regards Try to make it this way, it is shorter and clearer . (setq a (entsel)) (setq b (entget(car a))) (setq pt1 (cdr(assoc 10 b))) (setq pt2 (cdr(assoc 11 b))) (setq f (open "C:\\Documents and Settings\\Marco\\Mis documentos\\AAA.txt" "w")) ; ************************************************** ***************************** (setq ptx1 (rtos (car pt1) 2 4) pty1 (rtos (cadr pt1) 2 4) ptz1 (rtos (caddr pt1) 2 4)) xyz1 (strcat ptx1 ", " pty1 ", " ptz1) ) ; ************************************************** ***************************** (write-line xyz1 f) Regards, Tharwat Quote
Lee Mac Posted August 9, 2010 Posted August 9, 2010 Example: (defun c:test ( / ent p1 p2 file ) (if (and (setq ent (car (entsel))) (setq p1 (cdr (assoc 10 (entget ent))) p2 (cdr (assoc 11 (entget ent)))) (setq file (open "C:\\Documents and Settings\\Marco\\Mis documentos\\AAA.txt" "w"))) (progn (write-line (LM:lst->str (mapcar '(lambda ( x ) (rtos x 2 4)) p1) ",") file) (close file) ) ) (princ) ) ;;-------------------=={ List to String }==-------------------;; ;; ;; ;; Constructs a string from a list of strings separating ;; ;; each element by a specified delimiter ;; ;;------------------------------------------------------------;; ;; Author: Lee McDonnell, 2010 ;; ;; ;; ;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;; ;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; lst - a list of strings to process ;; ;; del - delimiter by which to separate each list element ;; ;;------------------------------------------------------------;; ;; Returns: String containing each string in the list ;; ;;------------------------------------------------------------;; (defun LM:lst->str ( lst del ) ;; © Lee Mac 2010 (if (cdr lst) (strcat (car lst) del (LM:lst->str (cdr lst) del)) (car lst) ) ) Quote
muthu123 Posted August 10, 2010 Posted August 10, 2010 Example: (defun c:test ( / ent p1 p2 file ) (if (and (setq ent (car (entsel))) (setq p1 (cdr (assoc 10 (entget ent))) p2 (cdr (assoc 11 (entget ent)))) (setq file (open "C:\\Documents and Settings\\Marco\\Mis documentos\\AAA.txt" "w"))) (progn (write-line (LM:lst->str (mapcar '(lambda ( x ) (rtos x 2 4)) p1) ",") file) (close file) ) ) (princ) ) ;;-------------------=={ List to String }==-------------------;; ;; ;; ;; Constructs a string from a list of strings separating ;; ;; each element by a specified delimiter ;; ;;------------------------------------------------------------;; ;; Author: Lee McDonnell, 2010 ;; ;; ;; ;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;; ;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; lst - a list of strings to process ;; ;; del - delimiter by which to separate each list element ;; ;;------------------------------------------------------------;; ;; Returns: String containing each string in the list ;; ;;------------------------------------------------------------;; (defun LM:lst->str ( lst del ) ;; © Lee Mac 2010 (if (cdr lst) (strcat (car lst) del (LM:lst->str (cdr lst) del)) (car lst) ) ) Dear Mr.Lee, Thanks again. Actually my aim is to convert any type of list which may contains numbers,strings,list etc into string and vice versa too. I hope you can solve this. If not explain what are the problems you can expect? Regards, Muthu. Quote
Kerry Brown Posted August 10, 2010 Posted August 10, 2010 In the context of your question Try this (vl-load-com) (defun c:prueba4 ( / a b pt1 pt1-str f) (setq a (entsel) b (entget (car a)) pt1 (cdr (assoc 10 b)) pt1-str (vl-prin1-to-string pt1) f (open "ppr.txt" "w") ) (write-line pt1-str f) (close f) (princ) ) Quote
muthu123 Posted August 10, 2010 Posted August 10, 2010 ;;;; Developed by R.Muthu Kumar ;;;;;;;; (defun lst-str (#list / fn file_descr a) (Setq fn (vl-filename-mktemp)) (setq file_descr (open fn "w")) (prin1 #list file_descr) (close file_descr) (setq file_descr (open fn "r")) (Setq a (read (read-line file_descr))) (close file_descr) (vl-file-delete fn) a ) Quote
muthu123 Posted August 10, 2010 Posted August 10, 2010 Dear friends, After long discussion I found a way to convert any list into string and vice versa. I hope it will be useful to the people whoever searching for the same task. ;;;---------------------By R.Muthu Kumar------------------------- ;;;---------------------Date:10-08-2010-------------------------- (Setq pt1 (list (list 0 "10" 0) 5 "SP-1" "splice" (list 5 2))) ;;;To Convert into String (setq str (vl-prin1-to-string pt1)) ;;;To Convert the String into List again (Setq #list (read str)) Regards, R.Muthu KUmar Quote
Kerry Brown Posted August 10, 2010 Posted August 10, 2010 Dear friends, After long discussion I found a way to convert any list into string Refer post #14 Quote
muthu123 Posted August 10, 2010 Posted August 10, 2010 Refer post #14 Dear Mr.kerry, I didn't see the same fuction you used in your post also. Anyhow finaly i hope we got solution what i was looking for long time. Can you find anyother way to convert a string into list? Regards, Muthu. Quote
Kerry Brown Posted August 10, 2010 Posted August 10, 2010 If you keep in mind that READ will return only the first expression in the string then read will be fine. for example be carefull of something like this 'cause it does exactly what you tell it to do. (setq a (entsel) b (entget (car a)) pt1 (cdr (assoc 10 b)) ) (setq str ( strcat (vl-prin1-to-string pt1) (vl-prin1-to-string a))) (read str) Quote
MSasu Posted August 10, 2010 Posted August 10, 2010 Dear msasu,Good one. do u have anyother routine to conver the string into list? Regards, Muthu @Muthu123, please check this post. Thank you! Regards, Quote
