Michaels Posted August 26, 2010 Share Posted August 26, 2010 Hello . I have seen lots of users using the undo command in different types and return values. So what are the complete types of undo command uses in Lisp ? Some users prefer it (command "_.undo" "group") and others (command "_.undo" "......... and so on. Thanks. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 26, 2010 Share Posted August 26, 2010 I'm not sure I understand you correctly... do you mean this type of useage: ;; Set an undo mark (vla-startundomark *activeDoc*) Edit: If so, then inside the VLIDE, hit the Apropos button, and search for "undo" Quote Link to comment Share on other sites More sharing options...
Michaels Posted August 26, 2010 Author Share Posted August 26, 2010 Thanks a lot . I meant the use of UNDO command itself . Some users use it with "end" and "group" and I would like to know the rest of using operations with UNDO command. And actually what's the meaning of group with undo ? Appreciated a lot. Quote Link to comment Share on other sites More sharing options...
alanjt Posted August 26, 2010 Share Posted August 26, 2010 Command: UNDO Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 26, 2010 Share Posted August 26, 2010 Based on yoru listed platform (AutoCAD 2011), this link may be useful: http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-5281.htm Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 26, 2010 Share Posted August 26, 2010 Oooo... Alan, lucky post # 4,000!!! Way to go big guy! :wink: Quote Link to comment Share on other sites More sharing options...
Michaels Posted August 26, 2010 Author Share Posted August 26, 2010 That's all I know with the normal use of Autocad command. I meant there are lots of other uses of undo command with Lisp I have seen before ,and what I could remember the one which is with group right now. Regards Quote Link to comment Share on other sites More sharing options...
alanjt Posted August 26, 2010 Share Posted August 26, 2010 Oooo... Alan, lucky post # 4,000!!! Way to go big guy! :wink: Ugh, I need to get back to work. Quote Link to comment Share on other sites More sharing options...
