CADkitt Posted September 9, 2010 Posted September 9, 2010 It looks so damn easy and still I don't manage to modify it. It should be able to select more then one dimension, and not select by box but just one by one. (defun c:2x (/) (vl-load-com) (vlax-put-property (vlax-ename->vla-object (car (entsel "Select diminsion to change")) ) "TextSuffix" (strcat "(2x)") ) ) I was also thinking of adding a variable for setting the 2x to 3x etc., but I don't know if it is really needed. (I can probably do this myself) Quote
Tharwat Posted September 9, 2010 Posted September 9, 2010 That's a single selection due to (entsel) function, So to move to multiple try the following . Here is a multiple selection set codes ... (defun c:2x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (setq obj (vlax-ename->vla-object ent) ) ) ) (princ) ) Good Luck. Tharwat Quote
CADkitt Posted September 9, 2010 Author Posted September 9, 2010 (edited) yeah I got it to work final result: (defun c:x55 (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(55x)") ) ) ) (princ) ) And with custom input: (defun c:xx (/ i ss ent obj num) (setq num (getreal "\nSpecify x Times: ")) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(" (rtos num 2 0) "x)") ) ) ) (princ) ) tnx Tharwat edit: final lisp 5d does degree (from %%d) 5c does circle (from &&c) 1 to 20 x works by just typing "1x" (without "") and "2x" "3x" till "20x" xx asks for user input. Limitation is that it overwrites the prefix always. (defun c:1x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(1x)") ) ) ) (princ) ) (defun c:2x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(2x)") ) ) ) (princ) ) (defun c:3x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(3x)") ) ) ) (princ) ) (defun c:4x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(4x)") ) ) ) (princ) ) (defun c:5x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(5x)") ) ) ) (princ) ) (defun c:6x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(6x)") ) ) ) (princ) ) (defun c:7x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(7x)") ) ) ) (princ) ) (defun c:8x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(8x)") ) ) ) (princ) ) (defun c:9x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(9x)") ) ) ) (princ) ) (defun c:10x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(10x)") ) ) ) (princ) ) (defun c:11x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(11x)") ) ) ) (princ) ) (defun c:12x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(2x)") ) ) ) (princ) ) (defun c:13x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(14x)") ) ) ) (princ) ) (defun c:15x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(15x)") ) ) ) (princ) ) (defun c:16x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(16x)") ) ) ) (princ) ) (defun c:17x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(17x)") ) ) ) (princ) ) (defun c:18x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(18x)") ) ) ) (princ) ) (defun c:19x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(19x)") ) ) ) (princ) ) (defun c:20x (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(20x)") ) ) ) (princ) ) (defun c:5d (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "%%d") ) ) ) (princ) ) (defun c:5c (/ i ss ent obj ) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextPrefix" (strcat "%%c") ) ) ) (princ) ) (defun c:xx (/ i ss ent obj num) (setq num (getreal "\nSpecify x Times: ")) (vl-load-com) (if (setq i -1 ss (ssget '((0 . "DIMENSION")))) (while (setq ent (ssname ss (setq i (1+ i)) ) ) (vlax-put-property (setq obj (vlax-ename->vla-object ent) ) "TextSuffix" (strcat "(" (rtos num 2 0) "x)") ) ) ) (princ) ) Edited September 9, 2010 by CADkitt something went wrong with 4x Quote
CADkitt Posted September 9, 2010 Author Posted September 9, 2010 I updated the script the 4x was missing and the 3x had (x4) Quote
Tharwat Posted September 9, 2010 Posted September 9, 2010 A very good work Marijn. I do recommend you to add the 'undo' for your codes, because if something went wrong you won't be able to go back to the original Dimension . (vla-startundomark (setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object))) ) ....... doing of routine .... (vla-endundomark *activeDoc*) Best Regards, Tharwat Quote
