flopo Posted September 29, 2010 Share Posted September 29, 2010 Hello everybody, Is it possible to make a random selection? let's say i have a drawing with all entities possible to be in a 2d drawing, and i want to select 10% from all entity, but randomly? Maybe to have an option to give the percentage of a random selection? Thanks! Quote Link to comment Share on other sites More sharing options...
David Bethel Posted September 29, 2010 Share Posted September 29, 2010 I'd try something like this: (defun c:randset (/ ss sl i en el ep pct qty); rs) ;;;SMadsen Random Number (defun randnum (/ modulus multiplier increment random) (if (not seed) (setq seed (getvar "DATE"))) (setq modulus 65536 multiplier 25173 increment 13849 seed (rem (+ (* multiplier seed) increment) modulus) random (/ seed modulus))) (cond ((setq ss (ssget "X")) (setq sl (sslength ss) i -1) (while (setq en (ssname ss (setq i (1+ i)))) (setq el (cons en el)))) (T (alert "\nNo Entities Found") (exit))) (initget 7) (setq pct (getreal "\nPercentage To Randomly Choose: ")) (setq qty (fix (* sl pct 0.01))) (setq rs (ssadd)) (while (> qty (sslength rs)) (setq ep (fix (* sl (randnum))) en (nth ep el)) (if (not (ssmemb en rs)) (ssadd en rs))) (eval rs)) ;Return Set RS -David Quote Link to comment Share on other sites More sharing options...
flopo Posted October 1, 2010 Author Share Posted October 1, 2010 Thanks, David! Quote Link to comment Share on other sites More sharing options...
David Bethel Posted October 1, 2010 Share Posted October 1, 2010 You're welcome. I'd suggest that you not 'Troll' various forums with the same request. A lot of us participate in multiple groups and it doesn't bode all that well. -David Quote Link to comment Share on other sites More sharing options...
marmo Posted October 13, 2010 Share Posted October 13, 2010 Hi:) I have not figured out how to operate the lisp. I think that creates a selection set, but how do I select a set of objects? For example i need to select randomly 20 blocks in a drawing where there are 100. This lisp provides the name of the selection set, but how do I select them? Thanks, Marco Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 13, 2010 Share Posted October 13, 2010 Hi Marco, Look into the sssetfirst function Quote Link to comment Share on other sites More sharing options...
marmo Posted October 13, 2010 Share Posted October 13, 2010 Hi Lee! The name of the set is this: What is the correct syntax to select it with "sssetfirst"? Thanks, Marco Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 13, 2010 Share Posted October 13, 2010 I would suggest that you read the VLIDE Help Files on sssetfirst, as these will answer all your questions, but: (sssetfirst nil (c:randset)) Should work. Quote Link to comment Share on other sites More sharing options...
marmo Posted October 13, 2010 Share Posted October 13, 2010 Yes! Works! Perfect! Thanks Lee! Marco Quote Link to comment Share on other sites More sharing options...
David Bethel Posted October 13, 2010 Share Posted October 13, 2010 Or if you are using the command line Command: _.Select SELECT Select objects: !rs <Selection set: 2> 20 found Select objects: After you have ran randset. -David Quote Link to comment Share on other sites More sharing options...
marmo Posted October 13, 2010 Share Posted October 13, 2010 Thanks David! It also works this way! Thanks so much for the lisp! Marco Quote Link to comment Share on other sites More sharing options...
