; error: bad argument type: numberp: nil
jpl
am using lisp routine ARC-PARK in 2011 and getting this error. Have seen older posts with same error, but not code savvy. None specifically addressing this lisp.
any help would be greatly appreciated.
;Tip1815: ARC-PARK.LSP PARKING ON AN ARC ©2002, Ron Engberg
;; This routine allows the user to place parking stalls along an arc.
;; Written by Ron Engberg 12-2000
;; Radians to degrees
(defun RTD ® (* (/ R pi) 180))
;; Degrees to Radians
(defun DTR ® (/ (* 2 pi) 360))
(defun
C:ARC-PARK (/ ENT ARC-PT1 STALL-W STALL-L ARC-SIDE ARC-DIR
STALL-COUNT ARC_LIST ARC-CPT ARC-DIAM S-ANG E-ANG
ARC-CIRC DELTA ARC-LENGTH STALL-ANGLE-IN STALL-ANGLE-OUT
ARC-BASE ARC-ROT-ANGLE
;; Screen echo off
(setvar "cmdecho" 0)
;; Set to World UCS
(command "ucs" "w")
;; Parking stall information
(setq ENT (entsel "\nSelect ARC: "))
(initget 1)
(setq ARC-PT1 (getpoint "\nStarting End of ARC: "))
(initget 7)
(setq STALL-W (getreal "\nStall Width: "))
(initget 7)
(setq STALL-L (getreal "\nStall Length: "))
(setq ARC-SIDE (getstring "\nInside or Outside : "))
(setq
ARC-DIR
(getstring "\nClockwise or Counter Clockwise : ")
) ;_ end of setq
(initget 7)
(setq STALL-COUNT (getint "\nNumber of Stalls: "))
;; Arc information
(setq ARC_LIST (entget (car ENT)))
(setq ARC-CPT (cdr (assoc 10 ARC_LIST))) ;center point
(setq ARC-DIAM (* (cdr (assoc 40 ARC_LIST)) 2)) ;arc diameter
(if (or (= ARC-SIDE "I") (= ARC-SIDE "i"))
(setq ARC-DIAM (- ARC-DIAM (* 2 STALL-L)))
) ;_ end of if
(setq
S-ANG
(cdr (assoc 50 ARC_LIST)) ;start angle
E-ANG
(cdr (assoc 51 ARC_LIST)) ;end angle
ARC-CIRC
(* pi ARC-DIAM) ;arc circumference
;arc length
) ; end arc info
;; Test for delta angle
(if (> S_ANG E_ANG)
(setq DELTA (+ (- 6.2831853 S-ANG) E-ANG))
(setq DELTA (abs (- S-ANG E-ANG)))
) ; end if
(setq ARC-LENGTH (* (cdr (assoc 40 ARC_LIST)) DELTA))
;; Angle for starter line
(setq
STALL-ANGLE-IN
(angle ARC-PT1 ARC-CPT) ;stalls inside arc
STALL-ANGLE-OUT
(angle ARC-CPT ARC-PT1) ;stalls outside arc
) ; end set group
;; Rotation info
(setq
ARC-BASE
(/ ARC-CIRC 360.0000) ;length per degree
ARC-ROT-ANGLE
(/ STALL-W ARC-BASE) ;degrees per stall
) ; end set group
;; Test for inside or outside
(if (or (= ARC-SIDE "I") (= ARC-SIDE "i")) ;case sensitive ?
(command "line" ARC-PT1 (polar ARC-PT1 STALL-ANGLE-IN STALL-L) "")
;if inside
(command "line" ARC-PT1 (polar ARC-PT1 STALL-ANGLE-OUT STALL-L) "")
;else, outside
) ;end if
;; Test for clockwise or counter clockwise
(if (or (= ARC-DIR "CCW") (= ARC-DIR "ccw")) ;case sensitive ?
(repeat STALL-COUNT
(command "array" "l" "" "P" ARC-CPT "2" ARC-ROT-ANGLE "Y")
) ;_ end of repeat
) ; if ccw
(repeat STALL-COUNT
(command
"array"
"l"
"P"
ARC-CPT
"2"
(- ARC-ROT-ANGLE (* 2 ARC-ROT-ANGLE))
"Y"
) ;_ end of command
) ;_ end of repeat
) ; else cw
) ; end if
;; Reset UCS
(command "ucs" "p")
;; Screen echo on
(setvar "cmdecho" 1)
) ;_ end of defun
Edited by jpl
