Could anyone tell me how to select all the xrefs in a drawings and move them to a specific layer (440_XREF)?
I've tried all other posts related to this topic, but unfortunately my knowledge of coding doesn't stretch further than:
(setq sel1 (ssget "x" '((0 . "insert"))))
this will select all blocks, including xrefs but I don't know how to filter them.
thanks
[b][color=BLACK]([/color][/b]defun c:xreflist [b][color=FUCHSIA]([/color][/b]/ tdef xl[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]setq tdef [b][color=MAROON]([/color][/b]tblnext [color=#2f4f4f]"BLOCK"[/color] [b][color=GREEN]([/color][/b]not tdef[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]= [b][color=GREEN]([/color][/b]logand [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 70 tdef[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] 4[b][color=GREEN])[/color][/b] 4[b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]setq xl [b][color=GREEN]([/color][/b]cons [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 2 tdef[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] xl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 xl[b][color=BLACK])[/color][/b]
You have to examine each BLOCK table defintion to determine if the BLOCK is an external reference
Step through the BLOCK table definitions using (tblnext)
If the BLOCK flag ( group 70 ) 4 bit is set,
then add the BLOCK name ( group 2) to the list 'xl
xl is a list containing the names of xrefs found
The problem then lays in the fact that some of these BLOCKs may nested in other xrefs, so that CHPROP cannot manipulate the layers.
Or it may be as simple as:
[b][color=BLACK]([/color][/b]foreach b xl
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 2 b[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.CHPROP"[/color] ss [color=#2f4f4f]""[/color] [color=#2f4f4f]"_LA"[/color] [color=#2f4f4f]"440_XREF"[/color] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
HTH -David
you can also do it this way
(setq xr_dwg (vla-get-activedocument (vlax-get-acad-object))
xr_blk (vla-get-blocks xr_dwg))
(vlax-for blk xr_blk
  (if (= (vla-get-IsXRef blk) :vlax-true)
    (setq xl (cons (vla-get-name blk) xl))
and used the second part of daivds :)
Great work pBe.
May I ask you how to get the full path of the Xref dwg. ?
Many thanks
  (if (= (vla-get-IsXRef blk) :vlax-true)(progn
  (print (vla-get-path blk))(princ))
just add (vla-get-path ..)
there you go
thanks michaels
Wonderful pBe.
Thank you so much For your time and for fast reply.
Greatly appreciated.
Michaels.
