Results 1 to 3 of 3
    Forum Newbie
    AutoCAD LT 2008
    Oct 2010
    4
    Default Can't change dimension text size
    Hello I hope someone can help me with this.
    Whenever I try to dimension a drawing in model space the text of the dimension comes out unreadably small.
    I go into dimension style manager, I click on modify and I click on the text tab but the text height and fraction height scale is greyed out!
    If I click on "new" dimension style the only option I get is to base it off my current dimension style with the text size greyed out again.
    Does anyone know how to change the text size of dimensions if at the option is greyed out?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,090
    Is it possible that you preset your text height in the STYLE command?
    Open up the Text Style dialog window and see if you have something entered where it says Height. If so, make it "0". Click Apply then close the window. Then go back to your DimStyle and see if you can change the text height of your dimensions.
    Forum Newbie
    GuyWalker's Computer Details
    Intel
    AutoCAD LT 2009
    Jul 2011
    Melbourne Australia
    8
    In my STYLE command I changed "standard" to have a text hieght of, lets say 50 rather than 0. then I set my dimensions in DIMSTYLE to standard and once i was using that as current for my dimensions, i just selected the dimensions and in properties changed it to 50 also and that worked
    good luck bro
  1. How to change text size
    By sharpooth in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Apr 2010, 07:14 pm
  2. Dimension text size related to line text size.
    By Wilbri in forum AutoCAD Beginners' Area
    Last Post: 16th Mar 2010, 09:30 pm
  3. Dimension text size
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2009, 03:30 pm
  4. 'Can't seem to get dim text size to change...
    By dpaulku in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jun 2009, 01:19 am
  5. cant change dimension text size
    By b.muqlueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Feb 2008, 03:46 pm
