samp17 Posted October 12, 2010 Share Posted October 12, 2010 Hi, Im having problems with inserting a block into a diagram. I can insert a block which is a dwg file and it is imported into the document. I cannot however then move this whole block to where it should be positioned. I cannot select the block so that I can rotate it. Does anybody have any ideas why this may not be possible? Cheers, Sam Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 12, 2010 Share Posted October 12, 2010 Try setting PICKFIRST = 1. You do so at the command line. While you're at it set PICKADD = 1 too. That will take care of your next question. Quote Link to comment Share on other sites More sharing options...
rkent Posted October 12, 2010 Share Posted October 12, 2010 The layer is locked? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 12, 2010 Share Posted October 12, 2010 Perhaps he inserted the block on the Defpoints layer. Quote Link to comment Share on other sites More sharing options...
