Results 1 to 3 of 3
    Senior Member
    Map 3D 2008
    Sep 2009
    114
    Default insert-block from other drawing
    Hello everybody,
    I want to this lisp for inserting blocks, but i want to use it in other way - i want to make my icon in my toolbar, and your lisp works together with a dcl. I don't need this dcl, i want to make a macro ... can you help me please? This is the routine that i'm talking about...
    Thanks!
    Code:
    ;;----------------------=={ Copy Block }==--------------------;;
    ;;  Copies the specified block definition from the specified  ;;
    ;;  filename to the ActiveDocument using a deep clone         ;;
    ;;  operation (Method inspired by Tony Tanzillo)              ;;
    ;;  Author: Lee McDonnell, 2010                               ;;
    ;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
    ;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
    ;;  Arguments:                                                ;;
    ;;  block    - string specifying block name to copy           ;;
    ;;  filename - filename of drawing from which to copy block   ;;
    ;;  Returns: Block definition in ActiveDocument, else nil     ;;
    (defun LM:CopyBlock ( block filename / acapp acdoc acblk acdocs dbxDoc item )
      (vl-load-com)
      ;; © Lee Mac 2010
      (setq acapp (vlax-get-acad-object)
            acdoc (vla-get-ActiveDocument acapp)
            acblk (vla-get-Blocks acdoc))
      (vlax-map-collection (vla-get-Documents acapp)
        (function
          (lambda ( doc )
            (setq acdocs
              (cons
                (cons (strcase (vla-get-fullname doc)) doc) acdocs
      (if
        (and
          (not (LM:Itemp acblk block))
          (setq filename (findfile filename))
          (not (eq filename (vla-get-fullname acdoc)))
          (or
            (setq dbxDoc (cdr (assoc (strcase filename) acdocs)))
              (setq dbxDoc (LM:ObjectDBXDocument))
              (not
                (vl-catch-all-error-p
                  (vl-catch-all-apply 'vla-open (list dbxDoc filename))
          (setq item (LM:Itemp (vla-get-Blocks dbxDoc) block))
        (vla-CopyObjects dbxDoc
          (vlax-make-variant
            (vlax-safearray-fill
              (vlax-make-safearray vlax-vbObject '(0 . 0)) (list item)
          acblk
      (and dbxDoc (vlax-release-object dbxDoc))
    ;;-----------------=={ ObjectDBX Document }==-----------------;;
    ;;  Retrieves a version specific ObjectDBX Document object    ;;
    ;;  Arguments: - None -                                       ;;
    ;;  Returns:  VLA ObjectDBX Document object, else nil         ;;
    (defun LM:ObjectDBXDocument ( / acVer )
      ;; © Lee Mac 2010
      (vla-GetInterfaceObject (vlax-get-acad-object)
        (if (< (setq acVer (atoi (getvar "ACADVER"))) 16)
          "ObjectDBX.AxDbDocument"
          (strcat "ObjectDBX.AxDbDocument." (itoa acVer))
    ;;-----------------------=={ Itemp }==------------------------;;
    ;;  Retrieves the item with index 'item' if present in the    ;;
    ;;  specified collection, else nil                            ;;
    ;;  Arguments:                                                ;;
    ;;  coll - the VLA Collection Object                          ;;
    ;;  item - the index of the item to be retrieved              ;;
    ;;  Returns:  the VLA Object at the specified index, else nil ;;
    (defun LM:Itemp ( coll item )
      ;; © Lee Mac 2010
      (if
        (not
            (setq item
              (vl-catch-all-apply
                (function vla-item) (list coll item)
        item
    ;;  Test Function
    (defun c:instbl ( / *error* doc blk dwg pt norm )
      (vl-load-com)
      ;; © Lee Mac 2010
      (defun *error* ( msg )
            (princ (strcat "\n** Error: " msg " **")))
      (if (and
            (setq blk (getstring t "\nSpecify Name of Block to Copy: "))
            (setq dwg (getfiled "Select Drawing to Copy From" "" "dwg" 16))
            (LM:CopyBlock blk dwg)
            (setq pt  (getpoint "\nPick Point for Block: "))
          (setq norm (trans '(0. 0. 1.) 1 0 t))
          (vla-insertBlock
            (if
              (or
                (eq AcModelSpace
                  (vla-get-ActiveSpace
                    (setq doc
                (eq :vlax-true (vla-get-MSpace doc))
              (vla-get-ModelSpace doc)
              (vla-get-PaperSpace doc)
            (vlax-3D-point (trans pt 1 0)) blk 1. 1. 1.
            (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 norm t))
    kruuger
    tool palette is good for that (no lisp required) ?
    kruuger
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    Hi Flopo,
    I'm in the middle of updating that code for my site, it should be on there soon.
    EDIT: Here: http://lee-mac.com/copyblockfromdrawing.html -- although this version does use a dialog.
    In the meantime, you can call the code using macro hence:
    Code:
    ^C^C(LM:CopyBlock "BlockName" "C:\\MyDrawing.dwg")
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  1. Insert a block by lisp: _.insert or another way?
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Nov 2010, 10:40 am
  2. Insert block, add circle, exlode, create block
    By rookie37 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jun 2010, 10:40 pm
  3. Insert Block from within Drawing - VBA
    By hairyuga in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Feb 2009, 05:45 pm
  4. Insert Block when open new drawing
    By matthewrussell in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Dec 2008, 12:44 pm
  5. Insert a 3D drawing into a 2d title block using SOLPROF
    By mfranke in forum AutoCAD General
    Last Post: 7th Jan 2008, 09:01 pm
