Results 1 to 2 of 2
    Super Member
    not specified
    Feb 2006
    527
    Default Using VBA to export a Pdf File from AutoCAD
    AutoCAD 2010
    Is there any VBA code to create a pdf file. Maybe using something like Exportpdf command
    in AutoCAD without the page setup menu. Some that could be put in a batch loop in VBA.
    Thank you,
    Super Member
    not specified
    Feb 2006
    527
    Default If anyone is interested, this is the code I found.
    Sub CreatePDF()
    Dim PtConfigs As AcadPlotConfigurations
    Dim PlotConfig As AcadPlotConfiguration
    Dim PtObj As AcadPlot
    Dim BackPlot As Variant
    'Create a new plot configuration with all needed parameters
    Set PtObj = ThisDrawing.Plot
    Set PtConfigs = ThisDrawing.PlotConfigurations
    'Add a new plot configuration
    PtConfigs.Add "PDF", False
    'The plot config you created become active
    Set PlotConfig = PtConfigs.Item("PDF")
    'Use this method to set the scale
    PlotConfig.StandardScale = acScaleToFit
    'Updates the plot
    PlotConfig.RefreshPlotDeviceInfo
    'Here you specify the pc3 file you want to use
    PlotConfig.ConfigName = "DWG To PDF.pc3"
    'You can select the plot style table here
    PlotConfig.StyleSheet = ComboBox3.Value
    'PlotConfig.StyleSheet = "Acad.ctb"
    'Specifies whether or not to plot using the plot styles
    PlotConfig.PlotWithPlotStyles = True
    'If you are going to create pdf files in a batch mode,
    'I would recommend to turn off the BACKGROUNDPLOT system variable,
    'so autocad will not continue to do anything until finishes
    'the pdf creation
    BackPlot = ThisDrawing.GetVariable("BACKGROUNDPLOT")
    ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
    'Updates the plot
    'Now you can use the PlotTofile method
    If PtObj.PlotToFile(Replace(ThisDrawing.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then
    MsgBox "PDF Was Created"
    Else
    MsgBox "PDF Creation Unsuccessful"
    End If
    'If you wish you can delete th plot configuration you created
    'programmatically, and set the 'BACKGROUNDPLOT' system variable
    'to its original status.
    PtConfigs.Item("PDF").Delete
    Set PlotConfig = Nothing
    ThisDrawing.SetVariable "BACKGROUNDPLOT", BackPlot
    End Sub
  1. Export/import drawing file to/from csv(text) file
    By mtjipta in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2010, 04:14 am
  2. how shall i export dwg file to 3d max
    By sudhaathreya in forum 3D Modelling
    Last Post: 9th Oct 2009, 06:19 pm
  3. Export DWG file with .txt or .CSV
    By DMS in forum AutoCAD General
    Last Post: 21st May 2009, 03:43 am
  4. How to export stl file from autocad 2006
    By luisitopwr in forum AutoCAD General
    Last Post: 14th Aug 2007, 11:16 pm
  5. HELP! with .sat file export in autocad 2006
    By bobray in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2006, 07:51 pm
