pBe Posted November 26, 2010 Posted November 26, 2010 quick question: What is the DXF code to switch of "Match Ttext Orientation to Layout" This codes rotates a "TEXT" entity. (defun c:test () (cond ((setq lin-a (car (entsel "\n Select Line"))) (setq lin-a (entget lin-a) pt1 (trans (cdr (assoc 10 lin-a)) 1 0) pt2 (trans (cdr (assoc 11 lin-a)) 1 0) ) (setq txt-lst (car (entsel))) (entmod (subst (cons 50 (angle pt1 pt2)) (assoc 50 (entget txt-lst)) (entget txt-lst) ) ) ) ) ) Problem with this is if the Match text orientation toggle is Yes.. it will not rotate Wheres the switch in DXF, I tried setting 72 to 0 but it still wont rotate? Quote
Tharwat Posted November 26, 2010 Posted November 26, 2010 Problem with this is if the Match text orientation toggle is Yes.. it will not rotate What do you mean by that ? Quote
pBe Posted November 26, 2010 Author Posted November 26, 2010 This one I understand that you can uncheck this on Text Style Dialog. but what if its already existing... i got stumped findingthe DXF for that Quote
Tharwat Posted November 26, 2010 Posted November 26, 2010 I could not get it within my Version 2010 . ** edit ** I just found it let chech it out and I may could help you with it. Quote
Lee Mac Posted November 26, 2010 Posted November 26, 2010 The annotative stuff is stored in XData, I believe the item you refer to is under the Appname: AcadAnnoPO (-3 ( "AcadAnnotative" (1000 . "AnnotativeData") (1002 . "{") (1070 . 1) (1070 . 1) (1002 . "}") ) [color=blue][b] ( "AcadAnnoPO" (1070 . 1) )[/b][/color] ) Quote
Tharwat Posted November 26, 2010 Posted November 26, 2010 Check post No. 10 , and try that routine which is included within . http://www.theswamp.org/index.php?topic=29722.0 Hope this help . Tharwat Quote
pBe Posted November 27, 2010 Author Posted November 27, 2010 The annotative stuff is stored in XData, I believe the item you refer to is under the Appname: AcadAnnoPO (-3 ( "AcadAnnotative" (1000 . "AnnotativeData") (1002 . "{") (1070 . 1) (1070 . 1) (1002 . "}") ) [color=blue][b] ( "AcadAnnoPO" (1070 . 1) )[/b][/color] ) okee.. so does that mean, if i can retrive it, i can modify and update it? Quote
pBe Posted November 27, 2010 Author Posted November 27, 2010 Check post No. 10 , and try that routine which is included within .Hope this help . Tharwat Thanks Tharwat i'll look into it Quote
Lee Mac Posted November 27, 2010 Posted November 27, 2010 (edited) okee.. so does that mean, if i can retrive it, i can modify and update it? I don't work with annotative stuff, but would believe so, yes. Something like this perhaps: (defun RemoveMatchOrientation ( entity ) (if (assoc -3 (entget entity '("AcadAnnoPO"))) (entmod (list (cons -1 entity) (list -3 '("AcadAnnoPO")))) ) ) Or maybe something to encompass both: ;; entity: Entity Name ;; flag : T=MatchOrientation, else nil (defun MatchOrientation ( entity flag ) ;; © Lee Mac 2010 (if (assoc -3 (entget entity '("AcadAnnotative"))) (entmod (list (cons -1 entity) (list -3 (cons "AcadAnnoPO" (if flag (list '(1070 . 1))))))) ) ) Edited November 27, 2010 by Lee Mac Quote
