Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 (edited) hello i have a problem with creating DCL window "on the fly" i want to do this in (getenv "TEMP") folder. on one computer there is no problem but on other there is error "Can't write DCL file" any solution? maybe (getenv "TEMP") is not a good option. can someone with (getvar 'LOCALE) other then: ENG ENU, PLK test this routine. language should be set to english as default (i hope so). thanks kruuger Aval.lsp Edited December 7, 2010 by kruuger Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 7, 2010 Share Posted December 7, 2010 kruuger: results from here, AC 2008 vanilla block name works OK tag name works OK value doesn't work, no response find doesn't get a response Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 kruuger: results from here, AC 2008 vanillablock name works OK tag name works OK value doesn't work, no response find doesn't get a response thanks stevesfr. that's great. i upload file one more time. now find button should works correct. i'm still concern about this DCL. kruuger Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 7, 2010 Share Posted December 7, 2010 thanks stevesfr. that's great. i upload file one more time. now find button should works correct. i'm still concern about this DCL. kruuger Now FIND works OK Value(s) for respective Tag(s) does not work Steve Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 Now FIND works OKValue(s) for respective Tag(s) does not work Steve hmm, it should work now. could you send me a sample file (with block) where is an error or wrong selection of blocks. thanks kruuger Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted December 7, 2010 Share Posted December 7, 2010 kruuger, What type of text editor are you using to write or save your code? Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 7, 2010 Share Posted December 7, 2010 hmm, it should work now.could you send me a sample file (with block) where is an error or wrong selection of blocks. thanks kruuger Attached is drawing with test block Steve test-br.dwg Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 Attached is drawing with test blockSteve Steve, how do you use this lisp? The purpose is to find user attribute value at selected blocks (also dynamic) and return selection set. Try my file. Select QUANTITY tag, enter value: 400 FT. Two blocks should be highlighted. i'm appreciate of your comments. kruuger test-br2.dwg Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted December 7, 2010 Share Posted December 7, 2010 kruuger, Again I am going to ask. What type of text editor are you using to write or save your code? Can you please tell me? It looks like you are using a text editor other than Vlide or Notepad. The code posted has the format all messed up and looks garbled. Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 kruuger, Again I am going to ask. What type of text editor are you using to write or save your code? Can you please tell me? sorry The Buzzard i didn't saw your previous post i'm using Notepad++. So far the best editor for me. few keyboard shortcuts tricks below if you are interesting. kruuger Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 kruuger, It looks like you are using a text editor other than Vlide or Notepad. The code posted has the format all messed up and looks garbled. ok, i see the problem. probably i need to change encode. but which one to choose? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 7, 2010 Share Posted December 7, 2010 Hmmm Notepad++ is OK, I use it for HTML/CSS but you can't beat the VLIDE for debugging One thing I have found with Notepad++ is that it doesn't seem to save my style preferences between sessions Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 7, 2010 Share Posted December 7, 2010 Hmmm Notepad++ is OK, I use it for HTML/CSS but you can't beat the VLIDE for debugging yes that's true, i agree One thing I have found with Notepad++ is that it doesn't seem to save my style preferences between sessions my works fine I update the code. Now i should be clean and nice at VLIDE. kruuger Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 7, 2010 Share Posted December 7, 2010 Steve, how do you use this lisp?The purpose is to find user attribute value at selected blocks (also dynamic) and return selection set. Try my file. Select QUANTITY tag, enter value: 400 FT. Two blocks should be highlighted. i'm appreciate of your comments. kruuger All works fine with above instructions / method. I had looked for different results. Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted December 8, 2010 Share Posted December 8, 2010 All works fine with above instructions / method. I had looked for different results. Thanks again Steve. kruuger Quote Link to comment Share on other sites More sharing options...
