be_bo Posted December 8, 2010 Posted December 8, 2010 I'm printing test.dwg to PDF using lisp routine. I'm using this expression to generate the file name: (setq pdf_name (getfiled "Specify file name to plot *.pdf" (getvar "SAVENAME") "pdf" 5)) On some computers it saves file as test.pdf On some computers it saves file as test.dwg.pdf. How I can set all computers to save test.pdf? Thank you! Quote
Lee Mac Posted December 8, 2010 Posted December 8, 2010 Using bit 5 (= 1+4) you are allowing any file extension, why not just use bit 1? (setq pdf_name (getfiled "Specify file name to plot *.pdf" (getvar "SAVENAME") "pdf" 1)) Or, if you want the pdf to match the drawing name, you could use something like: (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) ".pdf") [ Remember to use (vl-load-com) first ] Quote
be_bo Posted December 9, 2010 Author Posted December 9, 2010 Thank you, Lee Mac! My problem with extra extension was gone after I reloaded the profile, but your feedback is very useful for some other similar routines that I'm working on. Quote
