I am trying to get my dialog box to remember the last thing I entered for both fields. This is what I have but it doesn't work. I had a look at afralisp but I don't see where I'm going wrong. Can anyone help?
;; local defun by CAB (Charles Alan Butler)
(defun LayerMake_CPO (lyrname Color ltype)
 (if (tblsearch "LAYER" lyrname)
   (command "._Layer" "_Thaw" lyrname "_On" lyrname "_UnLock" lyrname "_Set" lyrname "")
   (command "._Layer" "_Make" lyrname "_Color"
            (if (or (null color)(= Color "")) "_White" Color) lyrname
            "LT" (if (or (null ltype)(= ltype "")) "Continuous" ltype) lyrname "")
(defun C:CPO (/ *error* ang col clr coords dwo elist midp offsetted ofpt osm p1 p2 p3 pline a b c name1 folio1 SUCE SUOM SUSM SUAB SUAD SUCL SUCR)
(setq dcl_id (load_dialog "cpo.dcl"))
    (if (not (new_dialog "cpo" dcl_id))
 (exit)
    );if
(setq SUCE (getvar "cmdecho"))
 (setq SUOM (getvar "orthomode"))
 (setq SUSM (getvar "osmode"))
 (setq SUAB (getvar "angbase"))
 (setq SUAD (getvar "angdir"))
 (setq SUCL (getvar "clayer"))
 (setq SUCR (getvar "cecolor"))
[color=red](set_tile "name" name1)[/color]
(action_tile "name" "(setq name1 $value)")
(action_tile "folio" "(setq folio1 $value)")
;(action_tile "accept" (val1))
(start_dialog)
(unload_dialog dcl_id)
 (setq a (strcat "CCC_CPO_"folio1"_"name1"_Grey_Hatch")
       b (strcat "CCC_CPO_"folio1"_"name1"_Outline_Red")
       c (strcat "CCC_CPO_"folio1"_"name1"_Outline_Black")
       d (strcat "CCC_CPO_"folio1"_"name1"_Leader"))
(defun *error* (msg)
 (if
   (vl-position
     msg
     '("console break"
"Function cancelled"
"quit / exit abort"
    (princ "Error!")
    (princ msg)
 (if osm (setvar "osmode" osm))
 (if clr (setvar "clayer" clr))
 (if col (setvar "cecolor" col))
 (if dwo (setvar "draworderctl" dwo))
 (command "._undo" "_END")
(Alert "Remember to draw the plot outline in an ANTI-CLOCKWISE direction.")
(command "_.insert" "CCC_CPO_Leader_Styles=" nil)
(command "_.purge" "_b" "CCC_CPO_Leader_Styles" "_n")
 (setq osm (getvar "osmode"))
 (setq col (getvar "cecolor"))
 (setq clr (getvar "clayer"))
 (setq dwo (getvar "draworderctl"))
 (command "._undo" "_BE")
 (setvar "osmode" 1)
 (setvar "cecolor" "bylayer")
 (setvar "HPORIGINMODE" 5)
 (LayerMake_CPO a "254" "Continuous")
 (LayerMake_CPO b "1" "Continuous")
 (LayerMake_CPO c "7" "Continuous")
 (LayerMake_CPO d "7" "Continuous")
(setvar "clayer" c)
(command "._pline")
(while (= 1 (logand 1 (getvar "cmdactive")))
(command pause))
 (setq pline (entlast)
elist (entget pline)
(setq elist (entmod (subst (cons 70 1)(assoc 70 elist)elist)));<--close pline
(entmod (subst (cons 43 0)(assoc 43 elist)elist));<--set line width to zero
(setvar "draworderctl" 3)
(command "_.draworder" pline "" "_F");<--set pline's draw order to front
(setq coords (vl-remove-if (function not)
  (mapcar (function (lambda (x)
        (if (= 10 (car x))(cdr x))))
   elist))
(setq p3 (caddr coords)
     p1 (car coords)
     ang (angle p1 p3)
     ofpt (polar p3 ang 1.0)
(setvar "clayer" b)
(command "._offset" 0.5 pline ofpt "")
 (setq offsetted (entlast)
 elist (entget offsetted)
;(command "chprop" offsetted "LA" b "")
;(command "_change" offsetted ""  "p" "layer" b "color" "bylayer" "")
(if (assoc 62 elist)
(setq elist (subst (cons 62 1)(assoc 62 elist) elist ))
(setq elist (append elist (list '(62 . 1))))
(entmod elist)
(command "._pedit" offsetted "_W" 1.0 "")
(command "_.draworder" offsetted "" "_B");<--set pline's draw order to back
   elist))
 (setq p2 (car coords)
midp (mapcar (function (lambda( a b)(/ (+ a b) 2)))
      p1 p2)
 (setvar "clayer" a)
 (setvar "hpname" "SOLID")
 (command "-hatch" "S" pline "" "")
 ;(while (> (getvar "cmdactive") 0)
   ;(command "\\") ;<- The Pause symbol will not pause the command. Backslash used instead.
 (setvar "hpname" ".")
 (setvar "clayer" d)
   (if (null (tblsearch "STYLE" "CCC_CPO_Leader"))
      (entmake
         (list
           (cons 0 "STYLE")
           (cons 100 "AcDbSymbolTableRecord")
           (cons 100 "AcDbTextStyleTableRecord")
           (cons 2 "CCC_Note_Numbers")
           (cons 3 "Verdana.ttf")
           (cons 40 0)
   (cons 74 1) ;Bold
           (cons 70 0)))))
(setvar "textstyle" "CCC_CPO_Leader")
(setvar "CMLEADERSTYLE" "CCC_CPO_Leader")
  (setvar "CMDECHO" 0)
(setvar "OSMODE" 0)
(command "_.mleader")
 (setvar "cmdecho"   SUCE)
 (setvar "orthomode" SUOM)
 (setvar "osmode"    SUSM)
 (setvar "angbase"   SUAB)
 (setvar "angdir"    SUAD)
 (setvar "clayer"    SUCL)
 (setvar "cecolor"    SUCR)
and the dcl for it:
cpo: dialog
{label = "CPO Layer Creation";
: edit_box
label = "Enter landowner name :";
key = "name";
alignment = centered;
edit_limit = 30;
edit_width = 30;
: edit_box
label = "Enter parcel number :";
key = "folio";
edit_limit = 10;
edit_width = 30;
: button
key = "accept";
label = "OK";
is_default = true;
fixed_width = true;
: errtile
width = 34;
Thanks.
Guest kruuger
you try to set control but your variable is nil
try this:
(if *name1*
   (set_tile "name" *name1*)
   (set_tile "name" "Default")
you need to save your variable as a global *name1* not local.
(action_tile "name" "(setq *name1* $value)")
you can also save it to registry
kruuger
Thanks kruuger. that did the job.
When you say save it to the registry do you mean as "appdata".
Does storing large amounts of data in the registry slow the machine?
I prefer to save to a cfg file, just to make for easier removal, however, storing small amounts of data in the registry shouldn't be too much of a problem - the drawback is that the user has to dig through the registry to remove the unwanted keys (which can be dangerous if they delete the wrong key).
If you wish to go the registry route, you can either use setenv/getenv which stores the keys under:
(strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\FixedProfile\\General")
Or use vl-registry-write to write to your own location - however, be very careful where path/key naming is concerned.
Guest kruuger
i usually save to registry data like: program version, dialog position, some dialog control settings etc.
(vl-registry-write "HKEY_CURRENT_USER\\Software\\Stuff\\Program1" "Version" "1.00")
(vl-registry-write "HKEY_CURRENT_USER\\Software\\Stuff\\Program2" "Language" "EN")
(vl-registry-read "HKEY_CURRENT_USER\\Software\\Stuff\\Program1"
"Version")
