cadeddie82 Posted December 15, 2010 Share Posted December 15, 2010 Is there a way to turn off the line work and keep the stationing, I am planning to use it as an xref. I tried turning of the layer and fr an instant it did keep the stationing but as soon as I regenerated the disappeared? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted December 16, 2010 Share Posted December 16, 2010 You should be able to go to the Display tab and redefine the layer for each feature in the alignment and labels. For instance, you could put the alignment on layer c-surf -algn and the labels on c-surf-iden. Then in your drawing you turn on c-surf-iden and turn off c-surf-algn. Quote Link to comment Share on other sites More sharing options...
