Results 1 to 10 of 10
    Full Member
    rwhitt0724's Computer Details
    Windows 7
    See details...
    rwhitt0724's Discipline Details
    Steel Detailer @ Misc. Fab Shop
    See details below.
    Steel Detailer Miscellaneous Items; Stairs, Railings, Nozzles, Platforms, Spiral Stairs, etc.
    AutoCAD 2011
    Oct 2009
    63
    Default AutoCAD 2010 - Polyline Quirk - Not showing up as solid when they are drawn solid
    I created a few blocks to use on a project we're doing. These blocks had Polylines in them that I have set to 13/16" thick. The problem is, when I am in the main drawing (not the block editor) the polylines are not showing up (or printing) as solid polylines. They look like rectangles. As do donuts that are also in the block, they are showing up almost as a star type shape (it is the correct size and shape, just does not view properly). The odd thing is, that both of the items are showing up perfectly fine in the block editor. I also used the "FILL" command to see if that could fix it and got no luck. I was able to recreate the problem on another computer. On the properly working computer, I turned the "FILL" option OFF and it looked just as it did on the 'broken' computer, except when I turn it to ON, it actually displays correctly. Does anyone have any other ideas what might be going on? Is it possible that the file has to many Polylines & Donuts in it and it is just to much so it is automatically doing this (the computer is not the best in the world but we've never had problems running AutoCAD on it, even Revit). I'm at a loss, the FILL thing totally threw me as I thought I'd figured it out but it worked on 1 computer but not on the one with the issue.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    What visual style are you using?
    Full Member
    Windows 7
    See details...
    See details below.
    AutoCAD 2011
    Oct 2009
    63
    I don't know what that means... Can you tell me how to check that?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    Visual styles: 2D wireframe, 3D wireframe, 3D Hidden, Conceptual, Realistic.... Any of these ring a bell?
  5. #5
    Full Member
    Windows 7
    See details...
    See details below.
    AutoCAD 2011
    Oct 2009
    63
    I believe we are using 2D wireframe? We draw everything in 2D here. Should I try setting the computer with the problem to a certain style? It's possible it may have been accidentally changed. Thanks for your help btw. I'm actually leaving the office now, so any suggestions you give I will try out in the morning and let you know how it goes. Thanks again.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    Did you know that after turning Fill "on" that you have to do a Regen for the polyline to display as "filled"?
    Other things that may affect the display of polylines that are not filled are as follows.
    Make sure your visual style is not set to 3D Hidden although I'm pretty sure it isn't. Type the letters VS at the command line and then press Enter. You should see this: <2dwireframe>.
    Make sure your UCS is set to World. Type UCS at the command line and then press Enter. You should see this: <World>. If it is something else change it.
  7. #7
    Full Member
    Windows 7
    See details...
    See details below.
    AutoCAD 2011
    Oct 2009
    63
    Ok, back to work (although the day is almost over again). I checked all of the settings you mentioned above and they all matched with what you were suggesting, still no luck. I did also do the regenerate. Here's a things I have checked and verified the settings are correctly configured:
    -Fill
    -UCS
    -Visual Styles
    -Regen after all settings changed
    I honestly don't know what to do now. My drawings are all changed and it's looking like I will have to go through all of these and redraw them. If you have any other suggestions I am completely open to trying anything. Please feel free to give as much input as you want.
    Thanks.
  8. #8
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    Quote Originally Posted by rwhitt0724 View Post
    -Fill
    -UCS
    -Visual Styles
    Thanks.
    -Fill = on
    -UCS = World
    -PLAN = World
    -Visual Styles = 2D
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    It's always the best laid PLANS of mice and men that trip us up.
  10. #10
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    If your view is not perpendicular to the UCS the polyline was created on, that also disables fill. Post your drawing (or at least a sample) and we'll figure it out instead of redrawing it.
  1. Polyline not solid
    By flyingjunkie in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Sep 2015, 05:22 pm
  2. AutoCAD: Best practice: fill hole in solid, remove region from solid
    By MichaelBrenden in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Nov 2010, 08:31 pm
  3. Solid Polyline
    By krishnakumaryadav in forum Electrical
    Last Post: 18th Jan 2010, 07:37 am
  4. Solid Hatching not showing up in Paper space?
    By Sarissa in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Oct 2009, 01:59 am
  5. AutoCAD 2010 Spell Checker Quirk.
    By ND5001 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 8th Sep 2009, 08:30 pm
