Richo Posted December 19, 2010 Share Posted December 19, 2010 not sure how to explain this correctly, so hopefully the image attached helps. okay, basically what i want to do is fill the red circle area with the same material as the blue circle (or a different material, unsure at this stage). There was one way where i just extend the walls across, but in doing so, it greatly affects the floor plan. so is there a way to put a surface material in this area? you see this in a lot of houses, and i want to find a way to do this in revit. i dont even know what to search, so sorry if there has already been a thread on this. hope somebody knows. if you dont understand my mumbo jumbo, say and ill see if i can explain it further Quote Link to comment Share on other sites More sharing options...
troggarf Posted December 20, 2010 Share Posted December 20, 2010 (edited) I think that you can: Select the wall, (preferably in an elevation view) Select "Edit Profile" While you're in editing mode, use the tools or erase lines... click & drag the ends of line to move them accordingly (You won't be able to close out of the editor if there any gaps) When you're finished, click the green check-mark to accept the changes and return to the last view you were in. Edited December 20, 2010 by troggarf Quote Link to comment Share on other sites More sharing options...
roof11 Posted January 20, 2011 Share Posted January 20, 2011 Hello Richo, sorry I jump in to your discussion.. I am a new user in revit. May I know how you copy and save the whole thing in revit viewport (the one you attached above). how did you save that figure from revit viewport? Quote Link to comment Share on other sites More sharing options...
troggarf Posted January 20, 2011 Share Posted January 20, 2011 If you are asking about how to save a picture of the screen... There is a button on your computer called "Print Screen" Sometimes it is abbreviated like "PRTSC" or "PRNTSCN". all you have to do is hold down CTRL or ALT or even a function key (that is colored) and then hit the "PRTSC" button. This takes a picture of what is displayed on your computer screen. Then you paste in to a picture editor and save. Quote Link to comment Share on other sites More sharing options...
roof11 Posted January 21, 2011 Share Posted January 21, 2011 wow as simple as that.. Thank you so much Troggarf.. Quote Link to comment Share on other sites More sharing options...
