sevdo2000 Posted January 23, 2011 Share Posted January 23, 2011 (edited) Hello, why when I use the press pull command in AutoCAD 2011 it moves and the ucs in xy plane (in this plane I saw but maybe and in the other). Wrong system variable maybe? In the previous version (2009) I use, it's not that ... DUCS is off Edited January 23, 2011 by sevdo2000 Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted February 1, 2011 Share Posted February 1, 2011 Plane is the key word if its 2d the extrude command is needed presspull is for 3d objects oh sorry about plane now i realize your talking about the directions in x and y id togle ducs on and off also is dynamic input on or off Quote Link to comment Share on other sites More sharing options...
sevdo2000 Posted February 2, 2011 Author Share Posted February 2, 2011 Thank you for the answer. DUCS ant DYN is turned off, but I now noticed that DUCS is turns on when I select press/pull, and turns off when exit it. Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted February 2, 2011 Share Posted February 2, 2011 ive had this problem at times when i looked at the view cube in 2011 i noticed it wasnt oriented correctly i just clicked on any of the possible views in the view tab and it was fixed at times i alternated between ducs and dui until it was solved if not i would just extrude a spline and go from there Quote Link to comment Share on other sites More sharing options...
