Lt Dan's legs Posted February 2, 2011 Posted February 2, 2011 I have a list like this (1 "A" "B" "C" 2 "A" "B") How would I go about getting ((1 . ("A" "B" "C"))(2 . ("A" "B"))) ? Quote
alanjt Posted February 2, 2011 Posted February 2, 2011 Quick and dirty... (defun test (lst / temp newlist) (foreach x (reverse lst) (if (numberp x) (setq temp (not (setq newlist (cons (list x temp) newlist)))) (setq temp (cons x temp)) ) ) newlist ) Quote
Lt Dan's legs Posted February 2, 2011 Author Posted February 2, 2011 Thanks! I was working on something similar but mine never worked out. Quote
alanjt Posted February 2, 2011 Posted February 2, 2011 Thanks! I was working on something similar but mine never worked out. Any time. Like I said' date=' it was [very'] quick and dirty. Quote
pBe Posted February 5, 2011 Posted February 5, 2011 I have a list like this(1 "A" "B" "C" 2 "A" "B") How would I go about getting ((1 . ("A" "B" "C"))(2 .("A" "B"))) ? Here's my attempt (defun test (ls / a b c) (foreach j ls (if (numberp j) (if a (setq c (cons (vl-list* (reverse b) a) c) a j b nil) (setq a j b nil)) (setq b (cons j b)) ) ) (setq newllist (reverse (cons (vl-list* (reverse b) a) c))) ) (test '(1 "A" "B" "C" 2 "A" "B")) ((("A" "B" "C") . 1) (("A" "B") . 2)) But for the love of me, i cant revese/construct the dotted pair to match the result Lt. Dan's legs request ((1 . ("A" "B" "C"))(2 .("A" "B"))) Alanjt I would have done it similar to your code but yours ended up with a non dotted pair.. any thoughts? glad the forum is up and running again Quote
MSasu Posted February 7, 2011 Posted February 7, 2011 But for the love of me, i cant revese/construct the dotted pair to match the result Lt. Dan's legs request ((1 . ("A" "B" "C"))(2 .("A" "B"))) Please don't forget that the second item of a dotted pair should be an atom, so the OP's request is a construction that isn't supported in AutoLISP. Regards, Mircea Quote
alanjt Posted February 7, 2011 Posted February 7, 2011 Please don't forget that the second item of a dotted pair should be an atom, so the OP's request is a construction that isn't supported in AutoLISP. Regards, Mircea And there's no point. You can still assoc a non-dotted pair list. eg. (using my sub) Command: (assoc 2 (test '(1 "A" "B" "C" "D" 2 "D" "F" "R" 5 "D" "E" "T"))) (2 ("D" "F" "R")) Quote
MSasu Posted February 7, 2011 Posted February 7, 2011 And there's no point. You can still assoc a non-dotted pair list. eg. (using my sub) Command: (assoc 2 (test '(1 "A" "B" "C" "D" 2 "D" "F" "R" 5 "D" "E" "T"))) (2 ("D" "F" "R")) I’m afraid it has to do with the consistency of accessing data stored in key & value style while still preserving the data type of the "value" (see associated lists): (cdr '(2 . 1)) will return 1 (cdr '(2 1 2 3)) will return '(1 2 3) (cdr '(2 (1 2 3))) will return '((1 2 3)) Regards, Mircea Quote
alanjt Posted February 7, 2011 Posted February 7, 2011 I’m afraid it has to do with the consistency of accessing data stored in key & value style while still preserving the data type of the "value" (see associated lists): (cdr '(2 . 1)) will return 1 (cdr '(2 1 2 3)) will return '(1 2 3) (cdr '(2 (1 2 3))) will return '((1 2 3)) Regards, Mircea Just use cadr instead of cdr to retrieve the sublist. Quote
