Dear all,
anyone can tell me why I put the same code into AutoCAD 2007 & 2011 is return result is not the same.
(entget (vlax-vla-object->ename (vla-item (vla-item (vlax-ename->vla-object (namedobjdict)) "AEC_VARS") "AEC_VARS_DWG_SETUP")))
AutoCAD 2007 ----->
((-1 . ) (0 . "AEC_VARS_DWG_SETUP") (5 . "48") (102 . "{ACAD_XDICTIONARY") (360 . ) (102 . "}") (102 . "{ACAD_REACTORS") (330 . ) (102 . "}") (330 . ) (100 . "AecDbObject") (102 . "{AEC_SUBOBJECT") (300 . "AecImpDictRecord") (100 . "AecImpObj") (3 . "") (100 . "AecImpDictRecord") (3 . "") (102 . "AEC_SUBOBJECT}") (102 . "{AEC_NULLOBJECT}") (100 . "AecDbDictRecord") (100 . "AecDbVars") (100 . "AecDbVarsDwgSetup") (70 . 0) (71 . 30) (72 . 2) (73 . 2) (74 . 0) (75 . 0) (76 . 2) (77 . 2) (78 . 4) (79 . 2) (10 0.0 0.0 0.0) (11 0.0 0.0 0.0) (50 . 0.0) (40 . 100.0) (41 . 96.0) (42 . 0.00542501) (44 . 0.0625) (45 . 96.0) (46 . 0.3048) (90 . 0) (91 . 4096) (92 . 0) (270 . 56) (271 . 2) (272 . 130) (273 . 2) (2 . " sq ft") (3 . " cu ft") (4 . "ACADARCH") (6 . "L120") (7 . "'") (8 . "m") (330 . ) (9 . "") (43 . 0.0416667) (5 . "AecLayerStd.dwg") (171 . 1) (172 . 1) (173 . 1) (174 . 1) (175 . 25) (280 . 1))
But the same code put into AutoCAD 2011, it return like this :
((-1 . ) (0 . "AEC_VARS_DWG_SETUP") (5 . "48") (102 . "{ACAD_XDICTIONARY") (360 . ) (102 . "}") (102 . "{ACAD_REACTORS") (330 . ) (102 . "}") (330 . ))
You might receive some help if you would place your code in code tags. See...THIS
With the jump to .net, less and less object properties in the vertical products (arch, civil 3d, mech, etc.) are available to LISP.
Use vlax-object-dump and you'll get more properties.
(defun c:dump ( / *error* grpoint gr e )
 (vl-load-com)
 (defun *error* ( msg )
        (princ (strcat "\n** Error: " msg " **"))
 (defun grpoint ( / gr ss )
   (while
     (eq 5 (car (setq gr (grread t 15 2))))
     (setvar 'lastpoint (cadr gr))
   (list (car gr)(getvar 'lastpoint))
 (while
   (not
     (and
       (princ "\n*To view properties & methods select an object or right click on an object to select the nested object (press any key to cancel)*")
       (setq gr (grpoint))
       (cond
         ( (and (eq 25 (car gr))(setq e (car (nentselp (cadr gr)))))
           (setq e (vlax-ename->vla-object e))
         ( (and (eq 3 (car gr))(setq e (ssget (cadr gr))))
           (setq e (vlax-ename->vla-object (ssname e 0)))
         ( (or (eq 25 (car gr))(eq 3 (car gr)))
           (prompt "\nMissed! Try again!")
         (t (prompt "*Cancel*")(exit))
 (vlax-dump-object e t)
 (textscr)
I know this really isn't called for but I'm bored
Does the 2011 version support AEC objects?
I forget to tell you I'm using Architecture 2011
I will follow the guideline in next time.
Thanks , actually I want to get back the item (270 . 56 ) for check, but in Architecture 2011 unable to get back this item. Any other methods to replace it ?
((-1 . <Entity name: 7ed2de40>) (0 . "AEC_VARS_DWG_SETUP") (5 . "48") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: 7ed33f18>) (102 . "}") (102 . "{ACAD_REACTORS") (330 . <Entity name: 7ed2de18>) (102 . "}") (330 . <Entity name: 7ed2de18>) (100 . "AecDbObject") (102 . "{AEC_SUBOBJECT") (300 . "AecImpDictRecord") (100 . "AecImpObj") (3 . "") (100 . "AecImpDictRecord") (3 . "") (102 . "AEC_SUBOBJECT}") (102 . "{AEC_NULLOBJECT}") (100 . "AecDbDictRecord") (100 . "AecDbVars") (100 . "AecDbVarsDwgSetup") (70 . 0) (71 . 30) (72 . 2) (73 . 2) (74 . 0) (75 . 0) (76 . 2) (77 . 2) (78 . 4) (79 . 2) (10 0.0 0.0 0.0) (11 0.0 0.0 0.0) (50 . 0.0) (40 . 100.0) (41 . 96.0) (42 . 0.00542501) (44 . 0.0625) (45 . 96.0) (46 . 0.304 (90 . 0) (91 . 4096) (92 . 0) [color="red"](270 . 56) [/color](271 . 2) (272 . 130) (273 . 2) (2 . " sq ft") (3 . " cu ft") (4 . "ACADARCH") (6 . "L120") (7 . "'") (8 . "m") (330 . <Entity name: 0>) (9 . "") (43 . 0.0416667) (5 . "AecLayerStd.dwg") (171 . 1) (172 . 1) (173 . 1) (174 . 1) (175 . 25) (280 . 1))
Edited by ahyin
 (vl-load-com)
   (while
 (while
   (not
     (and
       (setq gr (grpoint))
       (cond
 (textscr)
Thank you ! But it can't get the drawing units from CAD file. Can you tell how to get the drawing units by lisp.
