any body help!!!for place the leader line with text with particular layer(like 'Error' layer).!
I thing that you have to make a lisp to do that....
Something like that :
(defun c:le (/  lst10 str ent)
(setq   oldlay (getvar "clayer"))
(grtext -1 "Free Lisp LE from Cad-viet @ketxu")
;(setvar "clayer" "KCVN-MANH") : Leader Layer,del ";" and change with your layer
(defun loc (lst vl /) (setq lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) vl)) lst))))
(command "_qleader" pause pause pause)
(command \U+001B)
(setq ent (entget (entlast)))
(setq lst10 (loc ent 10))
(setq str (getstring T "\n Input String : "))
;(setvar "clayer" "KCVN-TEXT") ; Dtext Layer, del ";" and change with your layer
(setq mp (mapcar '+ (nth 1 lst10) (nth 2 lst10))
     mp (mapcar '* mp '(0.5 0.5 0.5)))
(wtxt_l str (mapcar '+ mp '(0.0 0.7 00))) ; 0.7 : space from text to Line Leader along Y axis
(setvar "clayer" oldlay)
(defun wtxt_l(txt p / sty d h1 h2 wf h) ;;;Write txt on graphic screen at p, midle bottom
(setq    sty (getvar "textstyle")
d (tblsearch "style" sty)
h1 (cdr (assoc 40 d))
h2 (cdr (assoc 42 d))
wf (cdr (assoc 41 d)))
(if (> h1 0) (setq h h1) (setq h h2))
(entmake (list (cons 0 "TEXT") (cons 7 sty) (cons 40 h) (cons 41 wf)(cons 72 1)(cons 11 p) (cons 1 txt) (cons 10 p))))
I want create One Layer "Error" and its should(Text and Leader) automatically place on that layer.How to correct this?any one help please?
(defun c:Test (/ p1 p2 p3)
(setvar “clayer” “Error”)
(if (and (setq p1 (getpoint "\nSpecify leader Starting point: "))
(setq p2 (getpoint p1 "\nSpecify Next point: "))
(grdraw p1 p2 7 1)
(setq p3 (getpoint p2 "\nSpecify Next point : "))
(redraw)
(initdia)
(if p3 (progn
(command "_.leader" "_non" p1 "_non" p2 "_non" p3 "_A" "" "_M" "")
(command "_.leader" "_non" p1 "_non" p2 "_A" "" "_M" "")
Try this :
(setvar "clayer" "Error")
(grdraw p1 p2 7 1)
(setq p3 (getpoint p2 "\nSpecify Next point <Annotation>: "))
(redraw)
(initdia)
(if p3
(command "_.leader" "_non" p1 "_non" p2 "_non" p3 "_A" "" "_M")
(command "_.leader" "_non" p1 "_non" p2 "_A" "" "_M")
thanks a lot ketxu..here how to define the text height and text colur ketxu
