ceeyespee Posted June 30, 2011 Share Posted June 30, 2011 While working on 2D drawing (not all the drawings), when I copy a part of the drawing, the system seems to hang for more than a minute and get restored in steps. I had tried -scalelistedit solution and to no effect. Can somebody help? Quote Link to comment Share on other sites More sharing options...
pendean Posted June 30, 2011 Share Posted June 30, 2011 (not all the drawings) may be the key here: outside files from other vendors? or other versions of AutoCAD (Like Civil or Architecture)? Quote Link to comment Share on other sites More sharing options...
irneb Posted June 30, 2011 Share Posted June 30, 2011 Try doing a -Purge RegApps as well. Also Audit the dwg. If there's still weird stuff happening, perhaps there's some vertical used to generate the drawing to begin with, see if you have the ObjectEnablers installed. Also try my DictEdit routine (post #7) to see what other dictionaries are still left in the drawing. Quote Link to comment Share on other sites More sharing options...
