YZ Posted July 25, 2011 Share Posted July 25, 2011 I use LT, so can only implement macros & DIESEL solutions. Can anyone think of a way to write a command that would toggle the frozen and thawed layers? To my knowledge I cannot use a Layer State because there are user generated layers that are unique with each drawing. Ultimately I delete the frozen layers and all objects on those layers, so anything that can return a list of layers from within a macro would be amazing. Quote Link to comment Share on other sites More sharing options...
YZ Posted July 28, 2011 Author Share Posted July 28, 2011 No such thing as a command or macro to Toggle OFF/ON layers or FROZEN/THAWED layers? If I was Autodesk I would make a LAYSWITCHFROZEN command. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 28, 2011 Share Posted July 28, 2011 Autodesk dont need to do it as it can be done via a program in various ways but not in LT Somebody out there if you can export a layer list LT!!! name and on/off etc then you could easily write a script (excel) to change layer states. Quote Link to comment Share on other sites More sharing options...
YZ Posted August 1, 2011 Author Share Posted August 1, 2011 I had never thought of this. Perhaps it is possible to import the layer list into a script file and let that populate which layers are set to frozen and which are set to thawed. Brilliant. I do not know how to export in this way, but I will look into it regardless. Thanks BIGAL. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 2, 2011 Share Posted August 2, 2011 Can you run the command layerstate its on the layers window as a button and you can save all on all off etc it would then be possible to change the file to the opposite and reload. you would load in say notepad and do a search replace Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 2, 2011 Share Posted August 2, 2011 (edited) The best I can come up with (without LISP): Thaw all layers: ^C^C^P._-layer;"thaw";"*";; Restore layers: ^C^C^P._layerp; Note that this will not account for any layer changes made once thawed. To have more functionality, LISP (or other code) is required Edited August 2, 2011 by BlackBox Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 3, 2011 Share Posted August 3, 2011 Had a quick go at this and layerstates apears to be supported by LT. Ok now how to do it layerstates export out it will write a las file which is a txt file you will find in this file two lines for every layer, 90 then say 11 which is = Off & frozen 90 3 = no plot 90 10 =frozen 90 0 = on & Thaw & no plot In word you can edit two lines in one go if you just change the 3 to say 11 it may screw up the las file color No 3, if a layer has a 11 in the name, you need to do a search and replace at least 4 times, do a macro and save it first is to put a dummy number in for Frozen say fXXXX then a dummy number for on onxxxx and so on then swap Fxxxx for a new ON number else you will make everything ON and can not work out what should be turned off. Make the edits then reload your las file. eg search replace 90^p3 with 90^pFxxx the ^p is end of line hence in middle changes 2 lines Hope this makes sense if you struggle with the word part post here once you have the macro done it would only take a min or two to do. heres the word macro for one change just copy paste contents for each on of frozen no plot etc Sub OnOff() ' ' OnOff Macro ' Macro recorded 8/3/2011 by ' Selection.Find.ClearFormatting Selection.Find.Replacement.ClearFormatting With Selection.Find .Text = "90^p0" .Replacement.Text = "90^ponthawnoplot" .Forward = True .Wrap = wdFindContinue .Format = False .MatchCase = False .MatchWholeWord = False .MatchWildcards = False .MatchSoundsLike = False .MatchAllWordForms = False End With Selection.Find.Execute Replace:=wdReplaceAll End Sub Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 5, 2011 Share Posted August 5, 2011 Its a good idea to let people know did this solve your problem. happy to help more. Quote Link to comment Share on other sites More sharing options...
YZ Posted December 1, 2011 Author Share Posted December 1, 2011 So sorry BIGAL, I only just noticed yours and Renderman's additional suggestions. I have not solved this yet, just haven't had a break in the workflow to do much 'tinkering'. I have found this menu when you right-click in the Layer Properties Manager. If I sort layers by ON/OFF then select all the OFF layers I can switch them ON, then right-click, Invert Selection and switch these layes OFF. Still clumsier than I hoped. I wish AutoCAD had a function to toggle a layer setting across all layers. Anyway, trust you BIGAL to have an ambitious solution. I love it. I will keep working on this, but have hit a snag trying to write the macro to export a LAYERSTATE. It seems that I cannot do it without a dialog box. Quote Link to comment Share on other sites More sharing options...
Manila Wolf Posted December 1, 2011 Share Posted December 1, 2011 Could this work? To Freeze all but current: - ^C^C-LAYER;F;*;; To Thaw all : - ^C^C_Laythw; Quote Link to comment Share on other sites More sharing options...
Manila Wolf Posted December 2, 2011 Share Posted December 2, 2011 Ah! Sorry. I am guilty of not reading the thread through properly. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 2, 2011 Share Posted December 2, 2011 -la t * I use this button all the time. to thaw all layers. Quote Link to comment Share on other sites More sharing options...
YZ Posted December 5, 2011 Author Share Posted December 5, 2011 Thanks for your input Dadgad and Manila Wolf. As a small scale example I have attached a picture of my layer properties manager. What I am trying to acheive is a button macro that will delete all the layers that are frozen, and the objects that are on them. At the moment I do this all a slow way using the following steps: 1. Button to lock all layers: ^C^C_layer LO * ^C^C 2. Then Thaw and Unlock the frozen layers (in layer properties manager GUI), then Select All objects in the model, then Erase. 3. And finish with the button to unlock all layers: ^C^C_layer U * ^C^C I'm hoping to streamline the step 2. But this is usually where you meet the end of macro's capabilities and need to start using LISP, so I'm not holding out much hope. Quote Link to comment Share on other sites More sharing options...
suka4luv Posted January 6, 2012 Share Posted January 6, 2012 Have u tried layer walk? Quote Link to comment Share on other sites More sharing options...
BlackBox Posted January 6, 2012 Share Posted January 6, 2012 No such thing as a command or macro to Toggle OFF/ON layers or FROZEN/THAWED layers? If I was Autodesk I would make a LAYSWITCHFROZEN command. Just for fun, this is the best I could do so quickly - I may need to revise the regen step - but give this a try: (defun c:LAYSWAP (/ *error* _swapVal _layswap) (vl-load-com) (princ "\rLAYSWAP ") (defun *error* (msg) (if acDoc (vla-endundomark acDoc)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** ")))) ; Fatal error, display it (princ)) (defun _swapVal (val) (if (= :vlax-true val) :vlax-false :vlax-true)) (defun _layswap (oLayer lst) (foreach item lst (eval item))) ((lambda (acDoc cLayer / mode) (initget "ALL FREEZE ON LOCK PLOT") (if (or (setq mode (getkword "\nSpecify mode [All/Freeze/On/Lock/Plot] <Freeze>: ")) (not mode)) (progn (vla-startundomark acDoc) (vlax-for oLayer (vla-get-layers acDoc) (if (/= (vla-get-name oLayer) cLayer) (cond ((or (= nil mode) (= "FREEZE" mode)) (_layswap oLayer (list '(vla-put-freeze oLayer (_swapVal (vla-get-freeze oLayer)))))) ((= "ALL" mode) (_layswap oLayer (list '(vla-put-freeze oLayer (_swapVal (vla-get-freeze oLayer))) '(vla-put-layeron oLayer (_swapVal (vla-get-layeron oLayer))) '(vla-put-lock oLayer (_swapVal (vla-get-lock oLayer))) '(vla-put-plottable oLayer (_swapVal (vla-get-plottable oLayer)))))) ((= "ON" mode) (_layswap oLayer (list '(vla-put-layeron oLayer (_swapVal (vla-get-layeron oLayer)))))) ((= "LOCK" mode) (_layswap oLayer (list '(vla-put-lock oLayer (_swapVal (vla-get-lock oLayer)))))) ((= "PLOT" mode) (_layswap oLayer (list '(vla-put-plottable oLayer (_swapVal (vla-get-plottable oLayer))))))))) ;;(vla-regen acDoc acAllViewports) (vl-cmdf "._regenall") )) (*error* nil)) (vla-get-activedocument (vlax-get-acad-object)) (getvar 'clayer))) Performing a LAYSWAP of the same option again will 'undo' the initial option. Quote Link to comment Share on other sites More sharing options...
alanjt Posted January 7, 2012 Share Posted January 7, 2012 Just for fun.... No "All" (preference): (defun c:LayTog (/ *error* lst option) (defun *error* (msg) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (princ (strcat "\nError: " msg)) ) ) (vla-startundomark (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) (initget "Freeze Lock On Plot") (if (setq option (cdr (assoc (getkword "\nSpecify toggle option: [Freeze/Lock/On/Plot]: ") (setq lst '(("Freeze" . freeze) ("Lock" . lock) ("On" . layeron) ("Plot" . plottable))) ) ) ) (progn (vlax-for layer (vla-get-layers *AcadDoc*) (vl-catch-all-apply 'vlax-put (list layer option (~ (vlax-get layer option)))) ) (vla-regen *AcadDoc* acActiveViewport) ) ) (*error* nil) (princ) ) With "All": (defun c:LayTog2 (/ *error* lst option) (defun *error* (msg) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (princ (strcat "\nError: " msg)) ) ) (vla-startundomark (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) (initget "All Freeze Lock On Plot") (if (setq option (cdr (assoc (getkword "\nSpecify toggle option: [All/Freeze/Lock/On/Plot]: ") (setq lst '(("All" . "All") ("Freeze" . freeze) ("Lock" . lock) ("On" . layeron) ("Plot" . plottable) ) ) ) ) ) (progn (cond ((eq option "All") (setq lst (mapcar 'cdr (cdr lst))) (vlax-for layer (vla-get-layers *AcadDoc*) (foreach opt lst (vl-catch-all-apply 'vlax-put (list layer opt (~ (vlax-get layer opt)))) ) ) ) ((vlax-for layer (vla-get-layers *AcadDoc*) (vl-catch-all-apply 'vlax-put (list layer option (~ (vlax-get layer option)))) ) ) ) (vla-regen *AcadDoc* acActiveViewport) ) ) (*error* nil) (princ) ) Quote Link to comment Share on other sites More sharing options...
YZ Posted January 16, 2012 Author Share Posted January 16, 2012 Thanks. Have u tried layer walk? I use LAYWALK for other things, but it does not toggle the frozen layers in this case. Also RenderMan and alanjt, thanks so much for the input. Where I work we still only have LT so I cannot implement these. So sorry. How do you put them together so fast? Have you got code generators that you use? Quote Link to comment Share on other sites More sharing options...
YZ Posted July 31, 2012 Author Share Posted July 31, 2012 Okay I think I may have simplified the logic: I want to automate (macro, script or DIESEL) the process of locking all frozen layers. It is beyond me to know how. Quote Link to comment Share on other sites More sharing options...
