BruceIMA Posted August 16, 2011 Share Posted August 16, 2011 I just stated using AutoCAD 2006 this summer as an intern for an engineering department. The program has become pretty easy to use and I thought i was getting the hang of it. All of a sudden, when i draw a line, circle, or another shape, i can't see the input bar that floats at the end of the line. What im talking about is the small display that always sticks to the end of the object your drawing. It displays the angle the line is drawn at, you can see what measurement you're typing in. Does anyone know how to turn it back on? Quote Link to comment Share on other sites More sharing options...
nicolas Posted August 16, 2011 Share Posted August 16, 2011 That's dynamic input. You must have turn it off accidentally. Use F12 to switch it on an off. Use tab to cycle among its input field and down arrow to display options depending on the commands used. Quote Link to comment Share on other sites More sharing options...
Tankman Posted August 25, 2011 Share Posted August 25, 2011 F12 as nicolas stated and, might you have a DYN button bottom screen? Have never used '06. Quote Link to comment Share on other sites More sharing options...
