Results 1 to 3 of 3
    Full Member john1983's Avatar
    AutoCAD 2009
    Jun 2008
    York, England
    58
    Angry Realistic view in 3ds max 2012 problems.
    Hi All
    I've just downloaded a trial of 3ds max 2012 but I have a problem with the realistic view port...
    If i draw a box, or any other shape it looks fine in the realistic view up until I click into the port then it all goes weird, the box starts to get chicken pox and goes all speckly... see image. why!!!.jpgAny idea why it would be doing this? when I first installed the program it was all ok, none of this chicken pox but all of a sudden its started doing it....
    I thought it could be something to do with my graphics card but then remembered it wasnt doing it when I first installed the program, have I pressed a key by accident to make it do this??
    any help would be great...
    AutoCAD 2009
    Jun 2008
    York, England
    58
    sorted!! it was my graphics card that was messing it all up.
    for anyone else that has this problem this is what I did to sort it
    go to Customize
    Preference settings
    Viewports
    at the very bottom there is a display drivers section, click choose driver and select direct3d then click ok
    the graphics card im using is the ATI FireGL V7350
    hope this helps
    John
    PS
    If this is wrong and anyone knows of any other solution please let me know.
    Senior Member Raudel Solis's Avatar
    Raudel Solis's Computer Details
    Windows 7
    Hp dv7 4073nr
    Core i7 720 Qm
    6gb Ram 2/6
    1Gb Ati 5650
    500 Gb internal Hd
    500 Gb External Hd
    Built in & 32" External Hd Monitor
    Architectural
    3ds Max 2013
    Nov 2010
    Arlington Texas
    475
    well thats not an issue just that the graphics card cant keep up with the new view port.
    with the new nitrous viewport you can actually simulate current scene lights in the view port.
    i cant go into details for the sake of time.. but just check out the manual and read about the new nitrous viewport.
  1. Classic view in 2012
    By Bogbadbob658 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Mar 2012, 05:49 pm
  2. Problems using iLogic in Inventor 2012
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 20th Apr 2011, 09:40 pm
  3. 2012 Installation Problems
    By stevsmith in forum Autodesk Inventor
    Last Post: 14th Apr 2011, 09:14 am
  4. Realistic View
    By siderus in forum AutoCAD General
    Last Post: 1st Feb 2011, 07:37 pm
  5. AutoCAD Architecture 2010 - Realistic View looks total black !
    By gnusselt in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Jan 2011, 07:56 pm
