Error in my code, Changing text in a layer to a other text style.
Hello,
I have my code and it works fine untill i have a layer in my drawing, where there are no text entity's in. If that is the case i get the following error;
"Command: ; error: bad argument type: lselsetp nil"
I have tried to add a If statement nil on my variable L14 but that did not remove the problem.
So to clarify: i belive the problem occurs because i have a layer but there is no "text" in that specific layer in the specific drawing. In other drawings there are so the code is needed and works if there is text.
Could anyone help me with the correct if statement to resolve this problem.
  (setq L14 (tblsearch "layer" "E_B_KV23_KABEL_LABEL_VB"))
 (if (/= L14 nil)
       (setq cnt 0 sset (ssget "x" '((8 . "E_B_KV23_KABEL_LABEL_VB"))))(setq len(sslength sset))(setq valid 0 erms "")
(setq cnt 0)
 (while (> len 0)
      (setq en (ssname sset 0))
      (if (= (cdr (assoc 0 (entget en))) "TEXT")
       (progn(command "change" en "" "" "" "isocp2_08" "" "" )(setq cnt(+ cnt 1))
(setq sset (ssdel en sset))(setq len(- len 1))
 (if (= L14 nil)
   (setq L14 nil)
Thanks in advance,
Bob
This Line
(setq len(sslength sset)) and the rest after that will run regardless of the result of (setq cnt 0 sset (ssget "x" '((8 . "E_B_KV23_KABEL_LABEL_VB")))) Nil or not
so try changing it to:
(if (and  (/= L14 nil)
            (setq cnt 0 sset (ssget "x" '((8 . "E_B_KV23_KABEL_LABEL_VB")))))
              (setq len(sslength sset))(setq valid 0 erms "")......
Thanks alot pBe.
That solved the problem like a charm :).
bob
