Results 1 to 10 of 10
    Full Member
    AutoCAD LT 2012
    Aug 2011
    79
    Default How to create a breakline an or jogline in a section
    Top of the evening folks;
    How do we do a break and or jogline in a section so we make things shorter? I did find the DIMJOGLINE command and that will be great for the dimensions but what about the other stuff, do we have to do that with a block or draw the thing, if that's the case what are you doing to handle this?
    Thanks
    James
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    You can use two viewports to compact the model without actually breaking it down. Here's how I do it when dimensioning in modelspace. http://www.screencast.com/t/lfjCNmgtQ
    If you dimension in Paperspace, I suppose you'd also have to use a wipeout to break the dimline between the viewports?
    Full Member
    AutoCAD LT 2012
    Aug 2011
    79
    Quote Originally Posted by nestly View Post
    Thanks Nestly;
    I keep getting the old "BREAKLINE UNKNOWN COMMAND" message in both model and paper space, I'm working in Autocad LT 2012 and this seems to be one of those commands that's left out, if anybody knows better please let me know how and where you get it to work.
    I did do the jogline that I needed it's not the hardest thing in the world to draw, I was just looking for the easy way.
    Thanks for your time.
    James
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Here's a dynamic block you may find useful?
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    Quote Originally Posted by buildman View Post
    Thanks Nestly;
    James
    BREAKLINE is an Express Tool and not available in LT.
  6. #6
    Full Member
    AutoCAD LT 2012
    Aug 2011
    79
    Nestly;
    This is just super, the very thing I was looking for, I knew it had to be out there somewhere.
    I really appreciate this.
    James
  7. #7
    Forum Newbie
    AutoCAD 2015
    Oct 2014
    2
    This is great! Possibly dumb question: how do I insert this into a drawing? Do I have to copy and paste? I tried saving it as a WBLOCK, and I tried just dropping in the file where I keep all the wblocks, but when I try to insert (INS) it I get "Invalid".
  8. #8
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Welcome to Cadtutor.
    The dynamic breakline is a block within a sample drawing, so to reuse, open the attached drawing select the breakline and drag/drop or copy/paste it into your drawing. You can also use Design Center to get it from the attached drawing into your other drawings. If you plan on using it frequently, then perhaps put it in your template file so it's already in every new drawing you start, or maybe put it on a tool palette.
  9. #9
    Forum Newbie
    AutoCAD 2015
    Oct 2014
    2
    Ah great idea, I will add it to my template.
    Thanks again!
    And thank you for the welcome
  10. #10
    Forum Newbie
    AutoCAD 2016
    Jan 2016
    1
    The problem with using a block for the break line is that a lot of times (most of the time) I use break lines in details. I insert details on detail sheets as blocks themselves. So, after I've placed one detail block, the subsequent detail blocks containing the break line block will assume the properties of the break line block in the first detail. This is not a problem of the breakline block per se, but of blocks in general. Using Revit terms, it would be nice if blocks had "instance parameters" in addition to "type parameters".
    It is unfortunate that it is so difficult to create a break line, a common drafting element, using AutoCAD LT.
    Thank you,
  1. Annotative Breakline (annotation)
    By qball in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd May 2011, 07:26 pm
  2. regarding breakline command
    By gvgbabu in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Apr 2011, 07:33 am
  3. How do I create a 2D Plan (Cross Section) w/ a Point Cloud
    By Oshie in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Feb 2011, 12:21 am
  4. Need Create a section line autolisp
    By Sandy31 in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jan 2010, 09:43 am
  5. Customize Breakline?
    By succu8us in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 09:27 pm
