rdharvey Posted September 15, 2011 Share Posted September 15, 2011 Hi, Does anyone know of a quick way to copy a part that is already in an asm and paste it like you can in Inventor. Surely you don't have to search for the part in the vault and drag it in each time... Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 15, 2011 Share Posted September 15, 2011 Ctrl drag new instance from browser. Quote Link to comment Share on other sites More sharing options...
rdharvey Posted September 15, 2011 Author Share Posted September 15, 2011 Awesome knew there would be an easy way thanks jd Quote Link to comment Share on other sites More sharing options...
shift1313 Posted September 15, 2011 Share Posted September 15, 2011 If you select the part in the feature tree CTRL-C also works. If you click in the assembly window you can CTRL-V as many instances as you want. Keep in mind these will be pasted in the identical location as the copied part so you will need to manually move them. If you need multiples this might be quicker. Quote Link to comment Share on other sites More sharing options...
