sorina Posted September 17, 2011 Share Posted September 17, 2011 Hi guys, Trying to plot but it doesn't work. I went to page set up manager, all good, printing in 1:50 scale but when i try to save it as a pdf, it just shows me it's loading ( see attached picture).[ATTACH=CONFIG]30033[/ATTACH] Any advice on this? Thanks a lot for your help again Quote Link to comment Share on other sites More sharing options...
daft vader Posted September 17, 2011 Share Posted September 17, 2011 You need to plot to pdf not save, Select dgw to pdf in the plot pull down and you should be sorted ok ? BTW your attachment isnt working Quote Link to comment Share on other sites More sharing options...
sorina Posted September 17, 2011 Author Share Posted September 17, 2011 hey, yes, sorry didn't make myself understood, yes, i was plotting to pdf... and it still doesn't work... Quote Link to comment Share on other sites More sharing options...
Murph_map Posted September 18, 2011 Share Posted September 18, 2011 With out seeing your attachment I will guess and say you are getting the "wait" when you are naming the pdf file. If so check all the paths in the support files in the options and make sure they are still active(not pointing to a directory that was deleted) then try changing the location to where you save the pdf to your local drive closer to the main c://. Long path names and folders can be a problem. Quote Link to comment Share on other sites More sharing options...
