iii76 Posted October 1, 2011 Share Posted October 1, 2011 Hello, I had to join the site to ask as google didnt bring much help. Basically trying to draw a rectangle at an angle of 80 degrees from the blue vertical line. Rectangle should be in the position where the blackline is drawn. Any advice or help is much appreciated. Thank you Pic: Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted October 2, 2011 Share Posted October 2, 2011 There are an assortment of ways to do that. You could draw the rectangle in x and y, then rotate it into position. You could draw a single line, rotate it into position, then offset the first line what ever distance you need, then connect the ends. All sorts of ways to do it. Either of these involve the rotate command. Check the Command Reference in the help file for instructions on using rotate. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 2, 2011 Share Posted October 2, 2011 Does Draftsight have a SNAPANG command? Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted October 2, 2011 Share Posted October 2, 2011 Does Draftsight have a SNAPANG command? There is, but it's undocumented in the help files, and for some reason I can't get it to work properly. Setting snapang to 80 in autocad does exactly what the OP is trying to do. Setting snapang to 80 in draftsight causes it to draw a line 84° away from vertical. if i set it to 90, it draws a line at 27° from horizontal. Think they got a bug in that command, which may be why it's undocumented. Quote Link to comment Share on other sites More sharing options...
eldon Posted October 2, 2011 Share Posted October 2, 2011 Perhaps the angles are radians, and not degrees Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted October 3, 2011 Share Posted October 3, 2011 Perhaps the angles are radians, and not degrees Good suggestion, but no, it's set for decimal degrees. Quote Link to comment Share on other sites More sharing options...
eldon Posted October 3, 2011 Share Posted October 3, 2011 Good suggestion' date=' but no, it's set for decimal degrees.[/quote'] Perhaps it is not picking up on the decimal degrees, because 90radians = 5156.6° = 116.6° (when subtracting n x 360), and 80 radians = 4583.7° = 263.7°. These angles are very close to those directions you were reporting Quote Link to comment Share on other sites More sharing options...
f700es Posted October 3, 2011 Share Posted October 3, 2011 Just as easy to draw it and then rotate IMHO. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted October 3, 2011 Share Posted October 3, 2011 Just as easy to draw it and then rotate IMHO. Agreed. That's why I suggested that first. And at least "rotate" works properly. I've dug into that snapang thing and can not make it work properly. As I said previously, the command is undocumented in the help files, so I suspect it just ain't ready for prime time yet. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted October 3, 2011 Share Posted October 3, 2011 You can rotate the ucs, or rather the ccs in draftsight by whatever angle is needed and that will work correctly. Don't know whats up with snapang. Quote Link to comment Share on other sites More sharing options...
