baker Posted November 1, 2011 Posted November 1, 2011 I am sorry, I did NOT search this.. but i am looking for a lisp that will create a table that creates the following on each layer in the drawing. column 1 = layer name in standard text column 2 = layer color in standard text column 3 = layer linetype in standard text column 4 = layer lineweight in standard text column 5 = layer transparency in standard text column 6 = layer plot (yes/no) in standard text column 7 = a line 1" (or unit) long i want this in a DWG file so i can plot with our settings. i know there is a way to export to excel.. that information would be great as well!! thank you for helping a lazy/busy guy out!!! Quote
BIGAL Posted November 2, 2011 Posted November 2, 2011 i know there is a way to export to excel.. = "You use the Data Extraction wizard" check help using lisp etc you can pull all the info out of the layer table now where is a example. Quote
alanjt Posted November 2, 2011 Posted November 2, 2011 Open the layer dialog; select all; ctrl+c; paste into excel. Quote
BIGAL Posted November 2, 2011 Posted November 2, 2011 using lisp also check out help under customization tblnext (while (setq lay (tblnext "layer")) (princ lay) ) Quote
Organic Posted November 2, 2011 Posted November 2, 2011 Open the layer dialog; select all; ctrl+c; paste into excel. That is a useful tip. I never knew you could copy those details from there. Quote
pBe Posted November 2, 2011 Posted November 2, 2011 (edited) Here's an old routine (defun c:Laytable (/ aDoc pt Ltable row_nos row_num ColNum row_nos BFlag fpt lylst lyn ss typ ) (vl-load-com) (setq aDoc (vla-get-activedocument (vlax-get-acad-object))) (defun _Dxf (en as flg) (cdr (assoc as (if flg en (entget en) ) ) ) ) (if (and (tblsearch "BLOCK" "1inch") (setq pt (getpoint "\nTable Insertion Point:")) (setq Ltable (vlax-invoke (vlax-get (vla-get-ActiveLayout aDoc) 'Block) 'Addtable pt 2 6 10 35 ) ) (progn (vla-settext Ltable 0 0 (vl-filename-base (getvar 'DWGNAME))) (setq row_nos -1) (mapcar '(lambda (i k) (vla-SetcolumnWidth Ltable (setq row_nos (1+ row_nos)) k) (vla-settext Ltable 1 row_nos i) ) '("Name" "Color" "LType" "LWT" "Plot" "Sample") '(100.0 30 50.0 40.0 20.0 30.0) ) (vla-put-regeneratetablesuppressed Ltable :vlax-true) (setq row_num (vla-get-rows Ltable)) (vla-insertrows Ltable row_num 10 1) T ) ) (progn (while (setq a (tblnext "LAYER" (null a))) (if (not (member (setq lyn (_Dxf a 2 T)) '("0" "Defpoints"))) (progn (setq b (tblobjname "LAYER" lyn) ColNum -1 Lylst (cons lyn Lylst) ) (vla-insertrows Ltable (setq row_num (1+ row_num)) 10 1) (Foreach itm (mapcar '(lambda (j / typ) (setq typ (_Dxf b j nil)) (cond (( = j 370) (setq typ (if ( = typ -3) "Default" (itoa typ)))) (( = j 290) (setq typ (if ( = typ 1) "Yes" "No"))) ) typ ) '(2 62 6 370 290) ) (vla-settext Ltable row_num (setq ColNum (1+ ColNum)) itm) ) (vla-SetCellType Ltable row_num (1+ ColNum) acBlockCell) (vla-SetBlockTableRecordId Ltable row_num (1+ ColNum) (vla-get-Objectid (vla-item (vla-get-blocks adoc) "1inch") ) :vlax-true ) ) ) ) (vla-put-regeneratetablesuppressed Ltable :vlax-false) (command "_zoom" "O" (entlast) "") (command "_explode" (entlast)) (setq ss (ssget "W" (setq fpt (polar pt 4.71238898 30.00) ;(* (setq rn_ (- row_num 2)) 10.00)) ) (list (+ (car fpt) 270.00) (- (cadr fpt) (* (- row_num 1) 10.00)) (last fpt) ) '((0 . "MTEXT,INSERT")) ) i (sslength ss) lylst_ (reverse lylst) ) (while (setq a (car lylst_)) (repeat 5 (setq ent (entget (ssname ss (setq i (1- i))))) (entmod (subst (cons 8 a) (assoc 8 ent) ent)) ) (setq lylst_ (vl-remove a lylst_)) ) (foreach itm (reverse lylst) (setq ent (entget (ssname ss (setq i (1- i))))) (entmod (subst (cons 8 itm) (assoc 8 ent) ent)) ) )(princ "\n<< Block Not Found >>") ) (princ) ) CODE UPDATED: HTH Edited November 3, 2011 by pBe Quote
baker Posted November 2, 2011 Author Posted November 2, 2011 @pBe - the routine worked.. however, each cell of the table was on zero layer. I was hoping to get the contents of each cell on the layer it lists. @alanjt - that will work.. and is not hard to do. thank you. @bigal - can you explain a but further? the reason i want the text and line work, it so i can plot out and make sure the lineweight and dithering and other variables are set up correctly. Quote
baker Posted November 2, 2011 Author Posted November 2, 2011 i did find this.. http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/layer-plot/m-p/2335067/highlight/true#M266533 it is a start for what i want. Quote
pBe Posted November 3, 2011 Posted November 3, 2011 (edited) @pBe - the routine worked.. however, each cell of the table was on zero layer. I was hoping to get the contents of each cell on the layer it lists. I think we can work it out. Do you want to exclude layer "0" & "Defpoints"? Updated code at post #6 Edited November 3, 2011 by pBe Quote
baker Posted November 3, 2011 Author Posted November 3, 2011 thank you.. those 2 layers do not matter much. ;-) Quote
baker Posted November 3, 2011 Author Posted November 3, 2011 (edited) 2 things i noticed.. 1) line weight decimal is off. showing 13 instead of 0.13 2) can plot be transparency instead? i no longer care about plot.. and if the layer plot is turned off.... umm... yeah.. lol. if so.. this lisp is perfect and exactly what i am looking for!! Edited November 3, 2011 by baker Quote
pBe Posted November 4, 2011 Posted November 4, 2011 2 things i noticed.. 1) line weight decimal is off. showing 13 instead of 0.13 look for this: ((= j 370) (setq typ (if (= typ -3) "Default" (itoa typ) ) ) ) Chang it to this ((= j 370) (setq typ (if (= typ -3) "Default" (rtos (* typ 0.01) 2 2) ) ) ) 2 things i noticed.. 2) can plot be transparency instead? i no longer care about plot.. and if the layer plot is turned off.... umm... yeah.. lol. if so.. this lisp is perfect and exactly what i am looking for!! Glad it worked for you. Cheers Quote
