motee-z Posted November 2, 2011 Share Posted November 2, 2011 hello to all can any one help me on how we can convert a 3d face drawing as in attached drawing or can be using autolisp routin Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
eldon Posted November 2, 2011 Share Posted November 2, 2011 Have you tried using the commands 3DSOUT and then the 3DSIN? If you look those up in your Help file, it will tell you how to do it. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted November 2, 2011 Share Posted November 2, 2011 Here's a really really old routine ( still has Compuserve info ) ;======================================================================= ; MakPface.Lsp Sep 19, 1998 ; Make A PFace Mesh From A Selection of 3DFaces ;================== Start Program ====================================== (princ "\nCopyright (C) 1998, Fabricated Designs, Inc.") (princ "\nLoading MakPface v1.5 ") (setq mpf_ nil lsp_file "MakPface") ;================== For Automated Calling From Another Program ========= (defun mpf_auto (ar1) (fa2pf ar1)) ;;;Supply PickSet Of Faces ;================== Macros ============================================= (defun PDot ()(princ ".")) (PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++ (defun mpf_smd () (SetUndo) (setq olderr *error* *error* (lambda (e) (and (/= e "quit / exit abort") (princ (strcat "\nError: *** " e " *** "))) (command "_.UNDO" "_END" "_.U") (mpf_rmd)) mpf_var '(("CMDECHO" . 0) ("MENUECHO" . 0) ("MENUCTL" . 0) ("MACROTRACE" . 0) ("OSMODE" . 0) ("SORTENTS" . 119) ("BLIPMODE" . 0) ("MODEMACRO" . ".") ("SNAPMODE" . 1) ("PLINEWID" . 0.0) ("ORTHOMODE" . 1) ("GRIDMODE" . 0) ("ELEVATION" . 0) ("THICKNESS" . 0) ("FILLMODE" . 0) ("SPLFRAME" . 0) ("UCSICON" . 1) ("HIGHLIGHT" . 1) ("REGENMODE" . 1) ("COORDS" . 2) ("CECOLOR" . "BYLAYER") ("CELTYPE" . "BYLAYER"))) (foreach v mpf_var (setq m_v (cons (getvar (car v)) m_v) m_n (cons (car v) m_n)) (setvar (car v) (cdr v))) (princ (strcat (getvar "PLATFORM") " Release " (substr (ver) 18 2) " - Make PFface Mesh ....\n")) (princ)) (PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++ (defun mpf_rmd () (setq *error* olderr) (mapcar 'setvar m_n m_v) (command "_.UNDO" "_END") (prin1)) (PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++ (defun SetUndo () (and (zerop (getvar "UNDOCTL")) (command "_.UNDO" "_ALL")) (and (= (logand (getvar "UNDOCTL") 2) 2) (command "_.UNDO" "_CONTROL" "_ALL")) (and (= (logand (getvar "UNDOCTL") 8) (command "_.UNDO" "_END")) (command "_.UNDO" "_GROUP")) (PDot);====== Convert A Selection Set Of 3DFaces To A PFace Mesh ======= (defun fa2pf (ss / slen i ed en ef vlist vlen tlist ln) (and (/= (type ss) 'PICKSET) (princ "** Invalid Parameter To FA2PF ** ") (exit)) (princ "\nDetermining Vertex Data\n") (setq slen (fix (sslength ss)) i (1- slen)) ;;;LAYER NAME (setq ln (cdr (assoc 8 (entget (ssname ss 0))))) (while (>= i 0) (setq en (ssname ss i) ed (entget en) i (1- i)) (and (/= (cdr (assoc 0 ed)) "3DFACE") (princ "\n** 3DFACES Only ** ") (exit)) (foreach g '(10 11 12 13) (if (not (member (cdr (assoc g ed)) vlist)) (setq vlist (cons (cdr (assoc g ed)) vlist)))) (princ (strcat "\r" (rtos (/ (* 100 i) slen) 2 0) "% "))) (princ "\nDetermining Face Data\n") (setq vlen (length vlist)) (entmake (list (cons 0 "POLYLINE") (cons 8 ln) (cons 10 (list 0 0 0)) (cons 66 1) (cons 70 64) (cons 71 vlen) (cons 72 slen))) (foreach v vlist (entmake (list (cons 0 "VERTEX") (cons 10 v) (cons 70 192)))) (setq i (1- slen)) (while (>= i 0) (setq en (ssname ss i) ed (entget en) ef (cdr (assoc 70 ed)) i (1- i) tlist nil) (foreach c '(1 2 3 4) (setq tlist (cons (cons (+ 70 c) (* (if (= (logand ef (expt 2 (1- c))) (expt 2 (1- c))) -1 1) (1+ (- vlen (length (member (cdr (assoc (+ 9 c) ed)) vlist)))))) tlist))) (entmake (list (cons 0 "VERTEX") (cons 8 ln) (cons 10 (last vlist)) (if (assoc 62 ed) (assoc 62 ed) (cons 62 256)) (cons 70 128) (nth 0 tlist) (nth 1 tlist) (nth 2 tlist) (nth 3 tlist))) (princ (strcat "\r" (rtos (/ (* 100 i) slen) 2 0) "% "))) (entmake (list (cons 0 "SEQEND")(cons 8 ln))) (command "_.ERASE" ss "") (redraw (entlast))) (PDot);************ Main Program *************************************** (defun mpf_ (/ m_v m_n olderr mpf_var ssface) (mpf_smd) ; (setq *error* nil) (setq ssface (ssget '((0 . "3DFACE")))) (fa2pf ssface) (mpf_rmd)) (PDot);************ Load Program *************************************** (defun C:MakPface () (mpf_)) (if mpf_ (princ "\nMakPface Loaded\n")) (prin1) ;================== End Program ======================================== ;Tested With R12_c3 DOS & R13_c4a Only ;Copyright (C) 1998, Fabricated Designs, Inc. ;"AS IS" Public Domain Software Donated By ; ; ; Fabricated Designs, Inc. ; 32 Maury Avenue ; Newport News, Virginia 23601-2132 ; Ph: (757) 595-5949 ; FAX: (757) 595-5787 ; CIS: 73544,2655 ; Internet: http://ourworld.compuserve.com/homepages/DavidBethel/ ; The problem being is that you can't do much with a polyface mesh. Have Fun! -David Quote Link to comment Share on other sites More sharing options...
motee-z Posted November 2, 2011 Author Share Posted November 2, 2011 thank you david bethel realy you help me thank you very much it work perfect up to acad 2010 but not work on cad2012 Quote Link to comment Share on other sites More sharing options...
David Bethel Posted November 3, 2011 Share Posted November 3, 2011 Mote-z, I don't see what could make the difference on this one. What does 2012 do that 2010 didn't? -David Quote Link to comment Share on other sites More sharing options...
motee-z Posted November 4, 2011 Author Share Posted November 4, 2011 sorry david i was mistak it works in both version Quote Link to comment Share on other sites More sharing options...
