Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2008
    Oct 2010
    9
    Default "Parametric" Text -- Text Based on Parameters/Dimensions
    Hey guys,
    Is there anyway to generate text based on other dimensions or parameters stored in the parameters manager?
    For instance, if I have a line that is 3" long, I'd like to have a note that says 'This line is 3"'. Or, if a circle is X feet in diameter, I'd like to have a note that says 'This circle is X feet'. These are just examples, but I hope you get what I'm saying.
    I'm using the new parametric modeling and doing some amazing stuff, but I'd like to parametrize my notes, too, if at all possible.
    Thanks.
    Senior Member edwinprakoso's Avatar
    edwinprakoso's Computer Details
    Windows 7 Home Premium
    Sony Vaio T11
    6 GB
    Intel HD4000
    AutoCAD 2013
    Nov 2009
    Jakarta, Indonesia
    275
    You can use fields to show your objects properties. You can use it to show parameters value or expression.
    This is a sample I use for labeling coordinate: http://cad-notes.com/2009/11/how-to-...te-in-autocad/
    Edwin Prakoso
    cad-notes.com
    The work doesn't matter if it's not built
  1. Replies: 2
    Last Post: 31st Aug 2010, 06:53 pm
  2. Replies: 6
    Last Post: 26th Aug 2010, 08:02 pm
  3. I need to send the output of the "LIST" command to a text file
    By evaristor in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2009, 06:57 pm
  4. Line w/text ex: _____6" Water______6"Water____
    By POaid in forum AutoCAD General
    Last Post: 19th Mar 2009, 01:52 pm
  5. Replies: 4
    Last Post: 3rd Sep 2008, 01:11 pm
