Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 41
  1. #31
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    rwhitt0724 - I agree with you, I don't use it as there are better ways to get around in 3D.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  2. #32
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 2000
    Quadro fx500
    2x 1920x1080
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD pre 2000
    May 2008
    Rockford, Illinois
    593
    Alex,
    I have a similar approach where I like as much screen area as possible. Here's a couple of things I do.
    I auto hide windows task bar.
    I reduce the command line to 1 line and simply F2 when I need more info.
    I use a dual monitor with AutoCAD on my left (main) monitor. On the second monitor I have the aerial view always on which allows for super fast zooming.
    My graphics card allows for easy switching to multiple desktops so I have several set up and open "outside" programs on other sesktops. This eliminates the need to minimize/maximize windows.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
  3. #33
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,586
    Quote Originally Posted by rkent View Post
    Rkent, this comes as a surprise to be honest. I figure you would be one who utilizes and loves the Navigation Cube. Simply out of curiosity, what are some of your ways you find better than the Nav Cube?
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  4. #34
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    I keep the ribbon on and minimized as I find more and more uses for it.
    I have several toolbars at the bottom and along the sides for customized
    macros, etc. I keep some toolbars and palettes on the second monitor
    along with the command line window. If I need a bigger screen I will
    use my custom clean screen work space as the built-in one eliminates too
    many tools for my use. With a work space I can have a few toolbars that
    are needed all the time.
    I have an ACADDOC.lsp file that loads my needed programs, (many through
    the Autoload function, this also loads a lisp file I call Qkeys.lsp and
    Settings.lsp. The Qkeys.lsp loads any alias commands I need and I don't
    modify the acad.pgp file as it seems redundant and a waste of time to
    maintain two files when one will do, and you can do a lot more in the
    lisp file compared to the PGP. The Settings file has lots of sysvars
    that I like to have set with each session.
    I have a folder C:\ACAD and I keep all my lisp files in this location.
    Under this folder I have C:\ACAD\LLL\XXXXX, with XXXXX being different
    named folders like TEXT, PLINES, MODIFY, DRAW, etc. holding lisp routines
    for those functions, making them easier to find when I am looking for one.
    I use Design Center quite a bit so I keep it on the second monitor and
    have my template defined for the home icon. I can quickly go there to
    pull layers, multileader styles, etc. into any drawing that doesn't have
    those already in it.
  5. #35
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,586
    If I need a bigger screen I will use my custom clean screen work space as the built-in one eliminates too many tools for my use. With a work space I can have a few toolbars that are needed all the time.
    Never thought of this. Great tip!!!
  6. #36
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    Hi Tanner,
    I use a combination of quick keys for the various views, SE for SouthEast, TV for top view, RV for right, etc. I use 33 for 3dforbit (free orbit) which I like a lot for arranging a model off of the assigned views. Finally I have the view tool bar set up to let me quickly pick one of the assigned views, see attached.
    For me I find the Navvcube gets in the way, is slower to use and requires more accurate picks which takes my focus off of the design and onto the function of making the program work.
    To each their own.
  7. #37
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,051
    Man, am I the only user left that still uses/displays the commandline?
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  8. #38
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    Quote Originally Posted by alanjt View Post
    I still use it, it is on the second monitor, although I am trying to use Dynamic Input more and more.
  9. #39
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    4,045
    Nope... I keep mine undocked, five lines shown + Command:, hovering the title block logo (which is populated by Fields + SSM Properties), +/-40% transparency. F2 when I want full view, and (textpage) is built-in to my "dump" functions for when I query Object Properties, Entity Data, etc.
    "Potential has a shelf life." - Margaret Atwood
  10. #40
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,586
    Hi Tanner,
    To each their own.
    Ah, I see. I used to use the View toolbar, granted not in the same orientation you have (which I love BTW). I will definitely agree that your way can be a much quicker way, but the Nav Cube is something I personally adopted immediately. I'm usually not like that which is kinda funny.
