sadhu Posted January 25, 2012 Share Posted January 25, 2012 (edited) I'm using the code below to add an attribute to a block. How do I rotate the attribute value (text) when it shows in the drawing ? Currently the attribute value shows horizontally. (vlax-invoke blk 'AddAttribute 4 ;text height acAttributeModePreset "attri-1" ; attribute tag (list (car Mi) (cadr Mi) 0.) ; insertion point "attri-1" ; attribute tag attri_value ;attribute value ) Edited January 25, 2012 by sadhu Quote Link to comment Share on other sites More sharing options...
MSasu Posted January 25, 2012 Share Posted January 25, 2012 One work-around is to modify the entity after was added - the rotation is stored in radians on DXF code 50. Regards, Mircea Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 25, 2012 Share Posted January 25, 2012 Please read the CODE POSTING GUIDELINES and edit your post. I see you made an attempt, but left the end portion off ....... [/code] Quote Link to comment Share on other sites More sharing options...
