wanted: vb code to vlisp migration
Ahankhah
Hi everybody,
should anyone help me converting this vb code to vlisp?
Public Declare Function LoadKeyboardLayout Lib "user32" Alias "LoadKeyboardLayoutA" (ByVal pwszKLID As String, ByVal Flags As Long) As Long
  LoadKeyboardLayout "00000409", 1
End Function
any help is greatly appreciated
This appears to set a specific keyboard layout current, perhaps for use of specifying a language (Arabic?). From MSDN:
Loads a new input locale identifier (formerly called the keyboard layout) into the system. Several input locale identifiers can be loaded at a time, but only one per process is active at a time. Loading multiple input locale identifiers makes it possible to rapidly switch between them.
Source: http://msdn.microsoft.com/en-us/library/windows/desktop/ms646305%28v=vs.85%29.aspx
HTH
Thank you RenderMan for your offer,
but I want to invoke this VB command inside my Visual Lisp code and don't know which external object should be invoked:cry::?:
Edited by Ahankhah
Finally, I find out the syntax :D:
(vl-load-com)
(defun C:English ()
(vlax-invoke
 (vlax-create-object "WScript.Shell")
 "run"
 "rundll32.exe user32.dll,LoadKeyboardLayout 00000409 1"
(defun C:Persian ()
(vlax-invoke
 "run"
 "rundll32.exe user32.dll,LoadKeyboardLayout 00000429 1"
But, althogh there is no error messages , windows does nothing. :shock:
Who knows why? :?
Ahankhah - One must vlax-release-object when accessing external objects in order to prevent catastrophic, sometimes even fatal, errors. Perhaps this is just my preference, but I also choose to use vlax-get-or-create-object instead, so as to obtain the existing object (if one exists) rather than always creating a new instance of said object.
Should there be a space after "user32.dll,"...? :unsure:
RenderMan, you are right and I thank you for your hint :D.
So the code should be replaced by this one:
(vl-load-com)
(defun ChangeLanguage (lang / shell)
(setq shell (vlax-get-or-create-object "WScript.Shell"))
(vlax-invoke
 shell
 "run"
 (strcat "rundll32.exe user32.dll, LoadKeyboardLayout " lang " 1")
(vlax-release-object shell)
(defun C:Persian ()
(ChangeLanguage "00000429")
(defun C:English ()
(ChangeLanguage "00000409")
Unfortunately not any result yet :cry:.
Edited by Ahankhah
Edited code according to Renderman's error trapping
Renderman,
1- I edited the code to cover your correction.
2- I ran it in AutoCAD and get the error message showing:
An exception occured while trying to run "rundll32.exe user32.dll, LoadKeyboardLayout 00000429 1"
while when issuing the following in the Window's Run edit box (Start->Run...) this way:
rundll32.exe user32.dll LoadKeyboardLayout "00000409" 1
there is no error message, and also not any desired result...:x
