Help with multiple offset code customisation
Hello guys,
What I need is explained in this picture:
Say I have a polyline/circle/line/arc in my drawing. I want to offset it twice in the direction I select and the amount of distance I enter. So it is just like normal offset command but I need it done twice in the same direction. Another thing I need is to change the colors. Color of the selected object has to be made "Cyan", the first offset has to have a white color and the second offset has to be "Cyan" again. That's all.
Here is the code I found on the internets (i think on this forum). I changed it to make just 2 offsets, it was a multiple offset code. It works great, I just need the color change code added in the mix:
(defun c:test (/ s i d p v)
;;; Tharwat 14. Dec. 2011 ;;;
 (if (and (setq s (car (entsel "\n Select entity :")))
          ;(member (cdr (assoc 0 (entget s))) '("LINE" "CIRCLE" "ARC" "ELLIPSE")) ;I had to removed this part (wasnt working with polylines)
          (setq i 2)
          (setq d (getdist "\n Distance of offset :"))
          (setq p (getpoint "\n Specify point on side to offset :"))
          (setq v d)
   (repeat i (command "_.offset" d s p "") (setq d (+ d v)))
Check this out ....
(defun c:TesT (/ s d p)
 (vl-load-com)
;;; Tharwat 24. Feb. 2012 ;;;
 (if
   (and
             '("LWPOLYLINE" "POLYLINE" "LINE" "CIRCLE" "ARC" "ELLIPSE")
      (command "_.chprop" (entlast) "" "color" "WHITE" "")
      (command "_.offset" (+ d d) s p "")
      (command "_.chprop" (entlast) "" "color" "CYAN" "")
I need to change the color of selected entity to CYAN as well. I tried to do it with:
(command "_.chprop" (s) "" "color" "CYAN" "")
but doesn't work. As far as I understand, you store the "name" of the selected entity in "s". Entlast also returns the "name" of the last added entity so it should work but incompatible data types maybe?
Edit: Oh nevermind, i see, i don't need the parenthesis. Works now. Thanks a lot.
Edit 2: Fix'ed the missing paren at the end.
 (vl-load-com)
 (if
   (and
      (command "_.chprop" s "" "color" "CYAN" "")
Edited by leventi
fixed the missing paren at the end
You're welcome .
the routine that you modified is missing one paren at the end .
Another
(defun c:test ( / clr ss e d)
(setq dist (cond ((getdist
                                      (strcat
                                            "\nSpecify Offset Distance"
                                            (if (numberp dist)
                                                  (strcat " <"
                                                          (rtos dist 2 2)
                               (dist)))
(while (and dist
           (setq ss (ssget "_:S:E:L"))
    (vlax-method-applicable-p (vlax-ename->vla-object (setq e (ssname ss 0))) 'Offset)
           (setq clr "7" d dist  pt (getpoint "\nSide to Offset")))
           (repeat 2
 (command "_.offset"  d e pt "" "_chprop" (entlast) "" "_color" clr  "")
                (setq clr "4" d (+ d dist))
      [color=blue][b] (command "_chprop" e "" "_color" clr "")
[/b][/color]       )
HTH
Edited by pBe
Another
(defun c:test ( / clr el ss e d)
(if (setq clr "7" dist  (cond
         ((getdist
            (strcat
              "\nEnter Distance [Enter to accept: <"
              (rtos (setq dist (if (null dist) 1.00 (getvar 'Offsetdist))) 2 2)
         (dist)
(while (and (setq ss (ssget "_:S:E:L"))
           (repeat 2
HTH
Hi pBe .
one line of code is needed :)
i updated the post.. thats always a problem when writing a code in haste :lol:
thats alwyas a problem when writing a code in haste :lol:
Agreed . :thumbsup:
Nice way of coding by the way .
Agreed . :thumbsup:
Thank you tharwat
I've fallen into a habit of copy & pasting snippets from other codes without checking the syntax. hence the error in coding
Anyhoo...
Cheers
Another
(if (setq  dist (cond ((getdist
                                      (strcat
                                            (if (numberp dist)
                                                  (strcat " <"
                                                          (rtos dist 2 2)
                               (dist)))
           (repeat 2
HTH
Hey, thanks to you too. I like that it remembers last offset distance and continues offset command untill you hit enter but it still doesn't change color of the selected entity to CYAN.
Oh... that.. :)
See Updated Code
Oh... that.. :)
See Updated Code
I had to add
(vl-load-com)
Works now thanks.
r
I had to add
(vl-load-com)
Works now thanks.
Anytime leventi.
Cheers
