Results 1 to 8 of 8
Thread: bak file
    Forum Newbie
    AutoCAD 2007
    Feb 2012
    3
    Default bak file
    i have some problem about BAK file. i accidentally change the program that open the bak file. then come a time that i need to use BAK file. i cannot rename it to .dwg the file will be XXX.dwg.bak. i had tried many ways to bring it back to unknown file just like before but none of them really work. please help anyone.. tanx. im using windows 7 & CAD2007
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    You don't need to set up a file type to open your .bak files. Just double click on the .bak file and select RENAME, then delete the bak and replace it with dwg, meaning that the file name ends with '.dwg' . Then when you click on it to open it, it should open with Autocad. If for some reason it is still trying to open with an inappropriate program, choose OPEN WITH and specify Autocad 2007.
    When you try to reformat the file type, you will be advised that it may make the file unopenable, ignore that and continue changing the .bak file type to .dwg and then you will be able to open it.
    Forum Newbie
    AutoCAD 2007
    Feb 2012
    3
    Default reply
    like i said i had already accidentally change the program that open it. i dont remember how it happened. now i cant rename it anymore. whenever i tried the file just became XXX.dwg.bak.
    AutoCAD 2012
    Nov 2011
    3,134
    Can you post it?
  5. #5
    Forum Newbie
    AutoCAD 2007
    Feb 2012
    3
    Default @gaddag
    see that the file name is "floor plan_1_1_8145 (.dwg" but the file is type is BAK. if i double click it AUTOCAD will open but with error or will stop responding. right now im reading some notes to help solve this problem. that i have search.. hope this one work. i have tried regedit but unluckily it didnt work. i'll post it anyway. thanks dadgad i appreciate your intention to help. god bless!!
  6. #6
    AutoCAD 2012
    Nov 2011
    3,134
    Change your file view to DETAILS, and display the column TYPE (not really necessary, but may prove informative). Right click on the file icon, then select RENAME. I just renamed one to .bak and back again to .dwg. It shouldn't be a problem, and yes, I realize you agree with that last statement. Sounds like you are now trying to use the DRAWING RECOVERY MANAGER, which should be another viable option. Right click on the .bak file and OPEN. That or you could try the system save version, and open that one.
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    What program were using using, or attempting to use, to open BAK files in the first place?
  8. #8
    Senior Member
    Structural
    AutoCAD 2011
    Sep 2011
    Baia Mare, Romania
    136
    Actually, you didn't change the extension from .bak to .dwg.... You just renamed file adding ".dwg" at the end.
    You must un-check option "Hide extensions for...
  1. Replies: 2
    Last Post: 11th Oct 2010, 10:10 pm
  2. Replies: 3
    Last Post: 24th Sep 2010, 05:48 pm
  3. Replies: 0
    Last Post: 21st Sep 2010, 01:31 pm
  4. Query on how to bring back the File browser or File Tree
    By CAnnondale in forum Autodesk Inventor
    Last Post: 25th Nov 2009, 01:05 am
  5. Converting CAD file into powerpoint file like video file
    By rattaka in forum AutoCAD Beginners' Area
    Last Post: 2nd Sep 2007, 05:46 pm
