Asterisk Posted March 6, 2012 Share Posted March 6, 2012 It doesn't allow offsetting a selected object anymore?.. My old routine was 1. Select an object 2. Enter Offset command 3. whatever 4. Exit Now when I start Offset command it deselects my object... The other commands are working fine with selected objects so far. Is there any way to make it work as before? Quote Link to comment Share on other sites More sharing options...
rkent Posted March 6, 2012 Share Posted March 6, 2012 It doesn't allow offsetting a selected object anymore?.. My old routine was 1. Select an object 2. Enter Offset command 3. whatever 4. Exit Now when I start Offset command it deselects my object... The other commands are working fine with selected objects so far. Is there any way to make it work as before? Even though it deselects the object it still works properly here but you might try setting PICKADD to 2. Quote Link to comment Share on other sites More sharing options...
Asterisk Posted March 6, 2012 Author Share Posted March 6, 2012 It was already 2. 0 or 1 changes nothing. Quote Link to comment Share on other sites More sharing options...
Asterisk Posted March 6, 2012 Author Share Posted March 6, 2012 Nevermind, I made it run as a Classic AutoCAD by removing profile string in the shortcut properties. Back to normal.... Quote Link to comment Share on other sites More sharing options...
Jerry cheng Posted May 29, 2012 Share Posted May 29, 2012 Not sure if this is caused by the PICKFIRST sysvar. Quote Link to comment Share on other sites More sharing options...
