Results 1 to 10 of 10
Thread: Data Extraction
    Forum Newbie
    AutoCAD 2009
    Mar 2012
    5
    Default Data Extraction
    How Can I extract Northing, easting , elevation from an AutoCAD drawing inot excel
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    Are we dealing with plain text or attributes here?
    Forum Newbie
    AutoCAD 2009
    Mar 2012
    5
    Hi Remark,
    Thanks for your reply, I just need a text file that has N,E,El. of every point in the drawing for example if I have a line i need the N,E,EI of the two points that line connect with
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    One method is to use the DATAEXTRACTION command.
    So these "points" are just that...points? They are not text objects or blocks with attributes?
  5. #5
    Forum Newbie
    AutoCAD 2009
    Mar 2012
    5
    I typed that command but did not get the result that I want, could you tell me how to proceed with this command to get my required result
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    I thought that AutoCAD 2009 had the Data Extraction wizard.
    On the Ribbon click on the Annotate tab > Tables panel, Extract Data icon.
  7. #7
    Forum Newbie
    AutoCAD 2009
    Mar 2012
    5
    no It has but as I go through this command it does not ask me to get N,E,EL it gives me other thing not the things that I want
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    No, data extraction does not specifically provide you with the information in the form you are used to seeing it in.
    You never answered this: So these "points" are just that...points? They are not text objects or blocks with attributes?
    It might help if you post a copy of the actual DWG file so we can see exactly what we are dealing with. Thanks.
  9. #9
    Forum Newbie
    AutoCAD 2009
    Mar 2012
    5
    The drawing attached has 3D Polylines, I need to extract their N,E,El for every vertex
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    You could always use the LIST command then open the text window and do a copy paste. Not the quickest method in the world.
    Or you can try Lee Mac's Point Manager program. Find it here...http://www.lee-mac.com/ptmanager.html
  1. Data extraction from viz 4
    By CHESTER007 in forum 3ds Max General
    Last Post: 17th Oct 2011, 11:14 am
  2. Data extraction
    By nsaudrey in forum AutoCAD Beginners' Area
    Last Post: 12th Apr 2011, 03:35 pm
  3. Data Extraction
    By Target in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2010, 10:42 am
  4. Data Extraction
    By RyanAtNelco in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2009, 08:16 am
  5. Data Extraction
    By Oasis in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2008, 04:37 am
