Kaars Posted March 14, 2012 Share Posted March 14, 2012 I have to solids. They are intersecting each other, I want to remove one solid which is inside. Does any body knows how to do it? It's a Civil 3D 2012 QUESTION. Quote Link to comment Share on other sites More sharing options...
Greendamo Posted March 14, 2012 Share Posted March 14, 2012 Hi Kaars, U will need to put it in to wireframe so you can see the internal 3D solid, then subtract it from the external solid using boolean subtraction. Quote Link to comment Share on other sites More sharing options...
Kaars Posted March 14, 2012 Author Share Posted March 14, 2012 Hi Greendamo, Thanks, Let me try this. Quote Link to comment Share on other sites More sharing options...
bill_borec Posted March 14, 2012 Share Posted March 14, 2012 You want to use the SU command (subtraction) when dealing with solids...however, be aware that the command will delete the solid that is being subtracted...so, if you need that element elsewhere, copy it to a different layer that is off/frozen prior to subtraction action. Quote Link to comment Share on other sites More sharing options...
Kaars Posted March 14, 2012 Author Share Posted March 14, 2012 Thanks Bill_Borec, It work's Quote Link to comment Share on other sites More sharing options...
bill_borec Posted March 14, 2012 Share Posted March 14, 2012 Glad to help! Quote Link to comment Share on other sites More sharing options...
